Old 10-17-2014, 02:28 PM   #1
kerjo530's Avatar
Only 1 slide came in and than the other 2 wouldn't move. Anyone have any suggestions?
When closing our 2007 Cedar Creek 5th wheel for the season last Sunday everything was going well, we were just about done, just needed to close the slides. We started to close them and the bedroom slide, which is the smallest, went right in no problem, but when we went to close the others nothing moved. The motor seems to sound fine,it's running the same as it did when it pulled the bedroom slide in, but nothing is moving. We see that we can do it manually with a power drill but we need a special bit for that and don't know where we can get one as we've enquires at RV places around here and no one seems to know what we are talking about.
Cb anyone offer some suggestions? We need help!
Thanks!
kerjo530 is offline   Reply With Quote
Old 10-17-2014, 02:42 PM   #2
Witch Doctor's Avatar
Call Cedar Creek parts dept admin. If it is the same as the new ones they can send you one. If they changed might be tough. Attached is there phone # good luck
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-17-2014, 04:12 PM   #3
GLCM Warrior
Lefty59's Avatar
Our Wildcat has two different type slide drives - a cable driven bedroom slide with the motor inside the RV above the slide. This slide needs a 'special' tool/bit to drive the motor with a drill. Our tool/bit was missing too, and Wildcat Chris said they were normally shipped in the fridge. Dealer got us one from another Wildcat he had on the lot (found one tool/bit in about 10 units he checked).
The living room slide in our Wildcat is a screw type drive that takes a crank handle inserted into a hole on the opposite side on the exterior of the RV to crank it in. We had problems with the supplied crank handle not properly fitting that shaft, but the dealer modified ours until we got it to work on the slide, the landing gear, and the rear stabilizers.
The 'special' bit isn't all that special and can probably be found in the tool department at a hardware store. It's a flex shaft with, I believe, an allen type head. Not sure exactly what size or exact shape as I don't have it in hand. The flex shaft can be bought separately and then a set of bits that fit into the flex shaft and the motor shaft shouldn't be too dificult to find.
One other thing to consider: The owner's manual for the rear stabilizers says to disconnect the battery before manually cranking the motor with the hand crank shaft. Not sure if the same precaution should be taken when manually moving the slides, but thought I'd mention it.
Sorry for your troubles. Hope you get the problem resolved.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 10-17-2014, 05:25 PM   #4
Not familiar with the 07 CC -are the slides hydraulic or motor driven?
If hydraulic, ours has shut off valves for each slide out, is it possible someone turn off the hydraulic valves ??
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 10-17-2014, 05:26 PM   #5
Plain Old Member
If your motor / pump is running, then no need to use the bit, as that's all the drill is going to do is turn the motor / pump. Obviously you don't have any isolation valves closed if you deployed them fine. Possible pump issue, hydraulic ram issue? I can't help much. I'm assuming you have 1 slide switch, and they come in starting with the smaller slide first, or do you have multiple switches? Not familiar with the 2007.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 10-18-2014, 09:34 AM   #6
When things calm down, fill us in with what happened and the fix.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 10-18-2014, 07:36 PM   #7
mycedarcreek's Avatar
If you turned the hydraulic valves off for any reason and then back open while pushing the button .they need to reprime the limes. And then go inside and use the slides control in the rv
mycedarcreek is offline   Reply With Quote
Old 10-19-2014, 05:32 PM   #8
kerjo530's Avatar
We did turn them on and off when it wasn't working. How do we reprime?
Old 10-19-2014, 07:00 PM   #9
Purging procedures from Lippert Systems:
http://lci1.com/assets/content/suppo...sheet/0183.pdf
and here is their level-up systems page:
Level Up
Walter & Donna
Old 10-20-2014, 02:09 AM   #10
kerjo530's Avatar
Thank you so much! We will give it a try this weekend and let you know how it works out!
slide
