Old 06-04-2015, 06:03 PM   #11
97flhtcui's Avatar
Fonzie,
The 1141 has a longer and narrower glass.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 06-04-2015, 07:34 PM   #12
Send a message via MSN to Tiggerdad
After you remove the lenses the information for the correct bulb will be stamped on the fixture.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-04-2015, 08:14 PM   #13
Ok thank you!
Spicyville1 is offline   Reply With Quote
Old 06-05-2015, 07:51 PM   #14
Former Full Timer
Duckogram's Avatar
Originally Posted by Probwrm19 View Post
Wish FR would ship LED light in yellow versus white. White lights are a big draw for bugs. They could then eliminate the old fashion yellow 12v light. Their design team needs some new blood with new ideas.
Methinks their design team drives horse & buggy. But seriously, here is the big question: Do LED lights attract bugs like incandescent bulbs?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 06-10-2015, 10:03 AM   #15
I think there is a wattage difference between the incandescent 1141 & the 1156.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 06-10-2015, 05:51 PM   #16
OLYGOLFER's Avatar
Whole thing re lights is confusing. Have a FR/CC/SilverBack 29ft that I cant identify the OEM bulbs for the interior candelabra lights in the left slide out. I assume they are BA15D. Cant find any info. The lights keep blowing out and over heating so I am sure the ones I replaced are incorrect. Do you have to disconnect the battery before replacing the fuse ? I cant find an icon for new thread anywhere either. Would some one mind emailing me at olygolfer69@gmail.com...thank you
OLYGOLFER is offline   Reply With Quote
Old 06-10-2015, 06:00 PM   #17
You are probably right about BA 15D. They make an LED equivalent which is what I use.
William & Sara
Old 06-15-2015, 11:46 AM   #18
Correction: LED Lights Do Attract Bugs. | Energy Circle
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 06-15-2015, 08:21 PM   #19
Former Full Timer
Duckogram's Avatar
Originally Posted by 38FLCamper View Post
Myth Busted. Seems to be credible sources and real science to debunk the myth.
Thanks for the link.
Old 07-26-2015, 05:44 AM   #20
flashman's Avatar
1141. Has the same socket as 1156 & 57
flashman is offline   Reply With Quote
door, light
