Old 06-03-2015, 09:51 PM   #1
outdoor light above the door
Hello, we have a 2014 36ckts. The lightbulb above the entry door burned out. The one with the oval yellow cover. What size bulb is it? I took the old bulb out but there were no numbers on it. Looks like an 1156. I put and 1156 in and it worked but the bulb gets too hot and started melting the yellow cover. Anyone know the correct bulb to use in the light? Thanks , Robert
Spicyville1 is offline   Reply With Quote
Old 06-03-2015, 10:08 PM   #2
Bus Driver
Deaver's Avatar
Not sure of the bulb, but they make an 1156 in an LED version. LED's are bright, use 84% less power and DON'T get hot
Click for Amazon LED's
Deaver is offline   Reply With Quote
Old 06-04-2015, 12:04 AM   #3
97flhtcui's Avatar
That bulb is a 1141. I replaced mine with a led that has a 1141 base.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 06-04-2015, 04:42 AM   #4
fonzie's Avatar
1141 vs 1156 bulb....what's the difference?
Fonzie
Old 06-04-2015, 07:18 AM   #5
Thanks for the replies. I will get the 1141 led and go from there!
Old 06-04-2015, 09:59 AM   #6
Certified Curmudgeon
Or you could replace the anemic porch light with the SL-1000 Starlight and not disturb your neighbors.
Mike Dropped
Old 06-04-2015, 10:53 AM   #7
That's a good idea Ducky, I looked at the website and I hope to order one soon
spock123 is offline   Reply With Quote
Old 06-04-2015, 11:46 AM   #8
Just ordered the star lights 1000. Will update on how well it works once installed. Thanks again!
Old 06-04-2015, 12:39 PM   #9
KAS
I don't like the light above the entry door since it attracts bugs. I did the following: I attached a "warm white" waterproof LED light strip underneath the entire length of the canopy metal strip where it is attached to the camper. The light strip length can be trimmed to fit. It is 12V or 120V (with a converter). I added an inline switch with remote control that lets me turn on/off and dim the lights among other functions. I absolutely love it!
KAS is offline   Reply With Quote
Old 06-04-2015, 05:03 PM   #10
Yellow exterior light
Wish FR would ship LED light in yellow versus white. White lights are a big draw for bugs. They could then eliminate the old fashion yellow 12v light. Their design team needs some new blood with new ideas.
Probwrm19 is offline   Reply With Quote
Old 06-04-2015, 06:03 PM   #11
97flhtcui's Avatar
Fonzie,
The 1141 has a longer and narrower glass.
MORryde IS 7000 LB
Kodiak Disc Brakes
Old 06-04-2015, 07:34 PM   #12
Send a message via MSN to Tiggerdad
After you remove the lenses the information for the correct bulb will be stamped on the fixture.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-04-2015, 08:14 PM   #13
Ok thank you!
Old 06-05-2015, 07:51 PM   #14
Methinks their design team drives horse & buggy. But seriously, here is the big question: Do LED lights attract bugs like incandescent bulbs?
Mike Dropped
Old 06-10-2015, 10:03 AM   #15
I think there is a wattage difference between the incandescent 1141 & the 1156.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 06-10-2015, 05:51 PM   #16
OLYGOLFER's Avatar
Whole thing re lights is confusing. Have a FR/CC/SilverBack 29ft that I cant identify the OEM bulbs for the interior candelabra lights in the left slide out. I assume they are BA15D. Cant find any info. The lights keep blowing out and over heating so I am sure the ones I replaced are incorrect. Do you have to disconnect the battery before replacing the fuse ? I cant find an icon for new thread anywhere either. Would some one mind emailing me at olygolfer69@gmail.com...thank you
OLYGOLFER is offline   Reply With Quote
Old 06-10-2015, 06:00 PM   #17
You are probably right about BA 15D. They make an LED equivalent which is what I use.
William & Sara
Old 06-15-2015, 11:46 AM   #18
Correction: LED Lights Do Attract Bugs. | Energy Circle
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 06-15-2015, 08:21 PM   #19
Originally Posted by 38FLCamper View Post
Myth Busted. Seems to be credible sources and real science to debunk the myth.
Thanks for the link.
Mike Dropped
Old 07-26-2015, 05:44 AM   #20
flashman's Avatar
1141. Has the same socket as 1156 & 57
flashman is offline   Reply With Quote
door, light
