UT_Grandpa has it right. There should be a coax connector on the outside of the trailer that has the door. That connection is only for hooking into a TV. Nothing else. It will duplicate what your TV gets on the inside, being the TV rooftop antenna.. On the other side of the trailer is possibly 2 coax connectors, maybe just one. If just one it should be marked "Cable". That is for hooking onto a park cable system. If are are 2 coax connections on the other side of the trailer than the second one will be marked Sat, as in Sat dish. To use the Cable input, first hook in the cable, then turn off the antenna booster switch, light off. Then set TV to cable input type and scan for channels.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
