10-05-2018, 09:24 PM
Outside Satellite/Cable Connectors
I have a 2013 36 CKTS, and it has satellite and cable connectors above the passenger side cargo door. The satellite connector appears to be an RCA jack instead of a coax jack. Is this normal, and what do I use to connect to it?
2017 F350 Powerstroke DRW 4x4
2013 Cedar Creek 36CKTS Custom
10-05-2018, 09:34 PM
sat tv or sat radio?
The Turners...
10-05-2018, 09:39 PM
TV. It has the Thule mount, DC plug, and the cable/satellite connections in the same area. I just put a TV in the cargo area and noticed the connector when hooking it up.
10-06-2018, 07:55 AM
Doesn't sound normal. All the ones I've seen/had are coax.
Got a photo?
10-06-2018, 07:59 AM
I have 2017 CKTS. I have one coax outside connection, nothing else. It's above the outside 110v receptacle to left of basement door on DS.
I have no idea where it goes. I don't use outdoor tv. Sorry.
FROG AR-0019-242
10-06-2018, 08:14 AM
Here's what I've got.
10-06-2018, 08:27 AM
Looks like a 12v cigarette lighter receptacle. As for the coax, you'll somehow have to find where the other end of the coax is for both of those connectors. Start in the wet bay.
FROG AR-0019-242
10-06-2018, 08:37 AM
Our outside TV "out" connection on the 2013 Puma had both RCA type jacks and coax for TV use.........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
10-06-2018, 08:43 AM
Yes - 12VDC on the right, coax for cable, and RCA for satellite. Both go into the wall, towards the bedroom.
First time I've seen an RCA plug for a satellite/cable/antenna input. I guess that's supposed to be fed video from a receiver/Jensen DVD player inside and audio thru the Jensen - is that the intent here?
I haven't pulled the bedroom TV out yet to check it out.
10-06-2018, 02:07 PM
Which side of the trailer?? are you sure that is not output.
1966 Mustang GT
1986 Mustang SVO
10-06-2018, 02:31 PM
Just as confused as you
It is most likely output for an outdoor tv. Otherwise the 12v outlet wouldn't be there.
Richard & Jill
10-06-2018, 02:42 PM
I agree... an output TO a tv.
That plate/outlet is likely fed from somewhere inside.
10-06-2018, 04:51 PM
Yes, they are output...when I said input,I was referring to input to the tv.
10-08-2018, 08:33 AM
The RCA looks yellow. I believe that would be a video only. Seems a little strange. I would have expected to see 2 more for Audio.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
10-08-2018, 12:51 PM
Originally Posted by 5picker
Doesn't sound normal. All the ones I've seen/had are coax. Attachment 188393
Got a photo?
If it's cable TV make sure to turn off the booster button
10-10-2018, 11:12 AM
Originally Posted by aknavy
Looks like a hook up for a external 12 volt tv.
Coachmen M/H
Concord
2018 / 300 DSC
