02-01-2016, 05:42 AM
Overspray removal
Need some assistance on what to use to remove an unknown substance which looks like a "glue type" overspray on the side of my Silverback.
Went to the mountains yesterday to wash and wax our unit in prep for heading to Florida for 6 weeks. 2 day mild weather break at above 60 degrees was perfect, 63 degrees ..
As I was totally exhausted having almost completed 1/2 of the unit, I thought I had come across a light black streak that may have run down from the roof. WRONG. It is an overspray of unknown material, but appears to be something like glue. It's also on the outside of my awning arm. I believe when it was in the shop last year in Indiana, maybe they were working on a unit next to mine and it got sprayed there. No other explanation.
I need to be very CAUTIOUS on the gel coat and decal. So basically I have tried only polish and "elbow grease" to no avail. This stuff is ON THERE.
All ideas and experiences appreciated.
02-01-2016, 07:11 AM
Testing a small area, I would try these chemicals in this order to find out which one works: WD40, denatured alcohol and then acetone, in that order. Once the glue is gone I would wash again and put a good coat of wax on the area you used to remove the glue as these chemicals will most likely remove any prior wax already applied.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
02-01-2016, 09:10 AM
I have been using a product Called Aero Cosmetics that was on display at the international F.R.O.G. rally last year. I saw a Cardinal that had this product applied and it really shined. So I went home looked this up and read the reviews on it. I did order this product and it really works.
I also ordered some cleaner products that seem to work for me and they could work for you also. One is called Safe Solv and the other one is Belly Wash. I would try the Safe Solv first as this seems to be the product that might work the best for your needs.
I have used the Wash Wax All and the Wash Wax All Degreaser and they really do work. In fact I wash my truck with the Wash Wax all and this does shine the truck and has bead up all winter long so far.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
02-01-2016, 04:39 PM
I don't know if you can get it there or not but there is a product called goo-gone available at Home Depot works well on glue and other sticky substances.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
02-01-2016, 04:52 PM
Who Dares, Wins
Just do jot get the goo gone on decals. It will melt them
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
02-01-2016, 07:08 PM
Goo gone
Tried that. No luck. Tnx.
02-01-2016, 07:20 PM
Overspray removal
I use isopropyl alcohol 90%.
Do not use 3m adhesive remover in the tin can- use the spray can. Different concentrations.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
02-01-2016, 07:36 PM
I think the alcohol may work. Now I am thinking the overspray is glue or sealant that may be an overshot from a spray gun when my front cap was replaced. The good news of the bad is they got it on awning arm. That gives me a removal test area! But, still concerned about applications of remover to gel coat and decal.
Thanks for the input.
02-01-2016, 07:40 PM
alot of body shops use isopropyl alcohol 90%.
02-02-2016, 10:11 AM
I had bad overspray on my vehicles from spray painting a fence (lesson learned). I used detailers clay (from auto parts store). Worked great and very easy.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
02-02-2016, 10:29 AM
Left Coast
Or auto paint store...
02-02-2016, 11:25 AM
Hey, great advice on the "detailers clay". Will get to Auto Zone today and study the container directions and go from there. I get overly concerned because it is also on the high gloss gel coat and decal.
02-05-2016, 04:25 PM
If the detailer's clay doesn't work, it sure does a fantastic job on the tow vehicle! Only other suggestion that I would have would be the Bug & Tar remover sold anywhere vehicle products are sold.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
02-05-2016, 04:47 PM
Meguiars #50 cleaner wax will take it off. I had the same thing on my 5ver
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
02-05-2016, 06:52 PM
Meguirs
I bought their "clay" and detail spray today.
Will be some time before I can use it as the rv is in the mountains of GA and weather is not cooperating.
Since the Meguirs cleaner 50 wax is likely easier, i will go get some and try that first. Tnx for the experience.
Anything special I need to watch for in applying over decals and gel coat OTHER than not rubbing too hard??
You can PM me if you prefer. We can end this thread conversation. Hopefully what info I have received will work and I thank everyone who responded. Heading for Florida in 3 weeks for 5 weeks. Pretty sure I will find time and cooperating weather to fix the Silverback!
02-05-2016, 07:08 PM
This is what I used to clean my new motorhome last year, spray (spray can) some on a soft cloth and rub gently.
02-05-2016, 07:50 PM
Georgia Rally Coordinator
X 2 but watch the decals. Gel coat is ok. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-05-2016, 07:51 PM
Don't use chemicals. Use a clay bar....
