Old 02-19-2015, 10:13 AM   #1
Paint flaked off
Last night was cold and I have camper at home but I keep heat on in the camper all the time, we go somewhere every month. The Cedar Creek can get down to zero with no problems, well this morning when I checked on camper where the furnace is all the paint had about flacked off. I wonder how that happen
spock123 is offline   Reply With Quote
Old 02-19-2015, 10:26 AM   #2
vinmaker's Avatar
Did it flake off the furnace or from the side panels? I would not be too concerned about the furnace itself. I can see the heat causing some paint problems on the hot surfaces of the furnace.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 02-19-2015, 10:36 AM   #3
From the furnace side, that can be painted with black paint and not be a problem but something like this has never happen with me before and I thought it was odd. I have always left the heat on in all the campers I have owned and this is a first. Do I need to make sure I have enough insurance?
Old 02-19-2015, 10:38 AM   #4
Oh this was not on the furnace itself but the panel that you can see from outside
Old 02-20-2015, 08:04 AM   #5
SilverbackMel's Avatar
Mine discolored after 3 months. They make/sell heat resistant paint at most automotive stores. I will be re spraying mine come Spring.
SilverbackMel is offline   Reply With Quote
Old 02-20-2015, 08:40 AM   #6
Witch Doctor's Avatar
I would check the furnace out your getting to hot from the burner if your outside door is flaking. Or could be just a cheap paint job from where ever FR bought it from. If it is really bad then I would leave that door open until you can get it checked out. You don't want the heat to transfer to your surrounding area on the trailer itself. Then you could have a real problem.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-20-2015, 02:14 PM   #7
dieselguy's Avatar
I've owned several fivers and have never had the paint blister from the cover. Is the cover actually aligned with the furnace exhaust port? (Wrong cover) Was there a strong wind against that side last night?
dieselguy is offline   Reply With Quote
