Old 05-02-2019, 08:05 PM   #1
Pedestal Table
Has anyone had a problem with the pedestal table detaching from the slide out? We traveled from MA to PA on Dr 84 and 81 which are pretty rough and when we got to our Harvest Host the table had pulled out of the floor. This is the second time weve had this problem. The plywood they use on the slide floor is 1/4.
gsv55 is offline   Reply With Quote
Old 05-03-2019, 03:51 AM   #2
SilhouettePenny's Avatar
This is a simple fix, remove the existing course thread screws then use a 3/8" spade bit to drill four additional holes (8 total) and reinstall using medium thread screws. Grind the tip of each screw to prevent damage to the flooring material, predrill and after installation use a paint marker to stain the inside of the drilled holes to match.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 05-03-2019, 10:19 AM   #3
keith52's Avatar
Are you sure your floor is 1/4 inch? Mine is 5/8 and is solid as a rock after 3 years and some pretty rough roads. I have even moved the table twice.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 05-03-2019, 06:52 PM   #4
Same here and I have moved the table two or three times
spock123 is offline   Reply With Quote
Old 05-03-2019, 07:03 PM   #5
Re checked Floor is 5/8 the problem is with the screws that wont hold. We will replace screws that will bite better. Why do they mount the pedestal on blocks? We took them off to make it less rocky.
Old 05-10-2019, 05:35 PM   #6
wayne272's Avatar
Had the same problem when I picked up my 36ck2 from Couch's and drove the 700 miles to long island. Parts of the nj turnpike and the cross bronx expwy. are brutal. Got home and opened up the camper and the table was laying on the chair with the mounting screws pulled out. I put bigger screws in with silicone on the threads. Will see if it holds.
wayne272 is offline   Reply With Quote
Old 05-11-2019, 11:21 AM   #7
That's the right thing to do, forgot to tell you that we did the same. Seems to be more stable without them.
2019.5 Hathaway
