Old 09-21-2016, 09:54 AM   #1
PIN Weight with Generator
Considering ordering the new 34RL2 which has a listed Hitch Weight of 2270. Amazon has the Onan 5.5kw LP generator showing a weight of 279 lbs. So by adding this generator I could expect the PIN weight to increase 279 lbs? I think this is a no brainer but just wanted to get a sanity check.
Understand there could be a couple of pounds of additional wiring but no increase for fuel since it would use the standard installed LP tanks.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=12 | Booked=42
florabama is offline   Reply With Quote
Old 09-21-2016, 10:00 AM   #2
Actually, not that simple. It all depends on where on the RV the generator is installed. The closer to the pin the gen is installed then more of its total weight is added to the pin. If behind the axles then it would decrease the pin weight. where does a generator install on your RV?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 09-21-2016, 10:02 AM   #3
Front storage compartment just behind the pin box.
Old 09-21-2016, 10:07 AM   #4
Fulltime family RVer
My guess is that you're right and the vast majority of it will end up as pin weight.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-21-2016, 04:28 PM   #5
X2
2016 Siverback 33IK
Old 09-21-2016, 05:56 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
I'm pretty sure that published weights do not include weight of options. In the case of a generator option, you also need to consider the weight of the 'Generator Prep' option which includes insulation and shielding to keep noise and more particularly fumes from penetrating the living space. When I checked into adding a generator to my front storage, I was shown storage bin lining that is basically an aluminum box that seals the bay. Also added was an exhaust pipe. Sorry, but I didn't ask what the weight add was. If you know someone with a front installed Onan, perhaps they can tell you what the pin weight add on was.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 09-21-2016, 06:04 PM   #7
Just curious but what is the price of the Onan? What does it run off?
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-21-2016, 06:45 PM   #8
WolfWhistle's Avatar
34RLS?
Pin to center of axle pair - in inches = PA
Pin to center of mass of the generator - in inches = PG
(PG/PA)*290 (279# plus a little for transfer switch, etc) = the ratio
the ratio * 290 = weight on axles
290 - weight on the axles = weight on pin
For example (a WAG) if the center of gravity for the genset is 60" behind the pin and the pin to axle pair center is 275". The pin will carry almost 227# and the axles a little over 63#
FWIW, I would consider the sound and vibration, installing a fire proof box / housing; how hard that would be to do. Buying it with generator prep would solve that issue.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 09-21-2016, 07:20 PM   #9
Runs on LP and cost about $4,200 just for the generator; not the prep. The option when ordered from FR is just over $6K.
Old 09-22-2016, 06:39 AM   #10
I ordered my 2017 34RE with gen. Prep which included transfer switch, metal shielding, all necessary wiring, control panel inside unit with hour meter and start/stop switch. If I remember wright, I think it was $270.00. I figured I could get an Onan cheaper and install it myself. Wiring harness just plugs into Onan. I haven't found any propane line for the generator installed yet. I'm thinking you have to add another tank so even more pin weight. All that weight adds up quick. Not sure if it's worth it.
cody1884 is offline   Reply With Quote
generator, weight
