Old 05-05-2012, 09:34 PM   #1
Exclamation Please help- where is my sink drain?
I recently bought a 2012 38fl fifth wheel cedar creek and am on my first camping trip. As my family takes their showers the shower will not drain and now the kitchen sink will not drain. I have dumped the grey tank but there are 2. When I push the sensor button I tank says empty while the other says full. Is there another pull or drain if not what is the problem. Thanks
Ulduck75 is offline   Reply With Quote
Old 05-05-2012, 09:46 PM   #2
jtstromsburg's Avatar
Not owning the same camper, but I would say there must be another valve. My friends 5er had a second grey pull valve, hidden behind a hose storage door. Keep looking around, maybe in an awkward place, but I bet you find one.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-05-2012, 09:55 PM   #3
fast murray's Avatar
Our rig has 2 separate valves for each tank and another for the black tank but they're all visible under the trailer.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-05-2012, 10:22 PM   #4
Now a "Top Member"
EdJunior's Avatar
My primary black/gray are in the normal area up front. But my second gray tank plunger is at the back of my camper, behind the super slide. It would be about 3 feet in front of the rear bumper. Look all along the outside of the frame, I bet you'll find it.
Oh, and I had the same problem. Of course this didn't get covered at the PDI!
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 05-05-2012, 10:31 PM   #5
You should have three valve handles. Two of them with be very near and the other one is probably just above the front tire. It is also very possible that the cable the handle attaches to is out of adjustment, broken, or otherwise not opening the valve.
Old 05-12-2012, 03:42 AM   #6
dare723's Avatar
Sounds like the galley tank is full and on ours, the galley handle is just forward the front tire separate from the others, while the bath and black tank handles are together under the cargo compartment. Just as donn stated. If one handle pulls real easy, problem. Geez....I just repeated what donn stated...I am so dumb...sorry donn....don't know they hid that 3rd. handle. Even harder to see if there is a slide adjacent to it that is open.
Walt and Connie Chatham
2009 Cedar Creek 34RLSA
2008 Dodge 3500 Cummins 6.7
dare723 is offline   Reply With Quote
Old 05-12-2012, 03:45 AM   #7
dare723's Avatar
Another thing to keep in mind, do NOT trust the sensors especially in the black tank. But in your case, not draining, sensor might be correct.
