Old 05-04-2015, 08:11 AM   #1
ret2006's Avatar
Popping Lippert level up
The left rear cylinder of my Level Up system seemed to pop and make noises when set up and level. I went through the procedure Lippert approved to add
ANTI-STICTION FLUID. I added a quart of the Maxima #15 Fork Oil, following the procedure step by step. It did not seem to correct the problem. The bulletin 0295 rev. 7/16/13, says that a second quart may be needed.
Has anyone had this problem and did the stiction fluid help or correct the problem?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 05-04-2015, 08:48 AM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
I had the same problem for a while 'til I ran into a fellow Cedar Creek owner who told me to use 6x6's for pads so that the struts were not extended so far. Haven't heard a pop since.....and also appears to have added extra stability
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 05-04-2015, 07:08 PM   #3
mguay's Avatar
Is it a POP or creaking that you guys are hearing? Mine creaks when you walk over the area of the jack. I tried using some taller blocks so the jacks wouldn't extend as much and it did get better. I'm going to get some bigger blocks for this weekend and give it a try. The other thing that I have noticed is that after I auto level the street side tires are about an inch off the ground. About an hour later they are touching. I was also going to try the Maxima Fork Oil as per the LIP sheet.
2015 GMC Denali DRW
2014 Dynamax Trilogy 3715FB
mguay is offline   Reply With Quote
Old 05-05-2015, 08:41 AM   #4
Same problem here. It took 2 quarts of fork oil to cure the popping. 2nd quart also cleared up a cylinder seepage problem.
Also talked to a owner who cycled the system a dozen or more times, they claim it was air trapped in the system.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 05-05-2015, 10:48 PM   #5
yes I have heard both, air in the system and adding forkoil,anti stickson, I added 1/2 qt to mine and cured the problem,i was parked for 2 mo and settled 2 in after adding fork oil no settling, I didn't know there was a TB on that, y doesn't the mfg just add fork oil at the factory, for mjuay that much leakage ,settling, is not normal, try auto leveling again to see what happens , it sounds like leakage in the system
Big Bill is offline   Reply With Quote
Old 05-13-2015, 08:51 PM   #6
mguay's Avatar
I leveled again and there was little to no settling however there was still popping. I'm thinking it was settling due to air in the system. I then did the fork oil tsb. And added the second qt. The creaking and popping is gone. The question I have is about the fluid tank. Mine doesn't have a cap per say. It is more like a seal with a 3/4" hole in the top. Is everyone's like this?
2015 GMC Denali DRW
Old 05-14-2015, 04:22 AM   #7
Former Full Timer
Duckogram's Avatar
All Level-Up systems are built by LCI and differ by application however I have never seen a reservoir without a cap. Keeping the contaminents out is essential so if you have a 3/4" hole I would think you are missing your cap. You might want to post in the Dynamax section and do include a photo.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 05-14-2015, 07:46 AM   #8
Jerry01's Avatar
If I recall correctly, the cap doesn't screw on it just pops in. Probably came off or was never on. Here is what mine looks like. Jerry Click image for larger version
Name:	ImageUploadedByForest River Forums1431607565.892195.jpg
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 05-14-2015, 08:07 AM   #9
clr
I have the same 6 point level up system on my Sanibel and to date I have had no problems. But just in case I was wondering how I might get my hands on the service bulletin 0295 that you reverence here. Thanks
clr is offline   Reply With Quote
Old 05-14-2015, 11:56 AM   #10
mguay's Avatar
Thanx Jerry for the pic. I am definitely missing the yellow cap.
2015 GMC Denali DRW
