Old 10-19-2014, 02:26 PM   #1
popping sounds
we have a Silverback 31RK, and we hear a popping type sound once in awhile, which sometimes feels like somone/something may have bumped into our unit. could that be the leveling leg on that side? (door side). we have the auto 6-pt leveling.
stormy2000 is offline   Reply With Quote
Old 10-19-2014, 06:56 PM   #2
Maybe the Lippert Level-Up Stiction problems - see the detail sheets.
http://lci1.com/assets/content/suppo...sheet/0295.pdf
I have heard this works in most cases, but some not so much.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 10-19-2014, 08:29 PM   #3
ping sound
So far I have put 2 quarts through this process. First quart was about 90% effective at first than got a little more often. 2nd quart about a month later has helped but have not been long enough to judge.
Get a pump of some type to extract and insert the oil. There was no way to get a device into the reservoir. Some designer never had to do this procedure.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 10-19-2014, 09:29 PM   #4
ok will see about some type of device which to extract the oil. maybe like a siphon? will see anyway. thanks for pdf and info.
Old 10-20-2014, 07:30 PM   #5
ping sound
One more thing I have learned in this process.
The oil is really a motor cycle fork oil.
DO not go to Harley shop, as there oil is specific to Harley and thus not of the spec that Lipert required.
There is multiple weights so get the 15 as specified.
A quart here was $15.00.
Good luck, let us know how you come out.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
Old 10-22-2014, 04:31 PM   #6
By the way, the popping sounds hurt absolutely nothing. So if you can learn to ignore them, you'll be just as well off. I hardly hear them anymore except at night when things are real quiet!
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
