Old 08-19-2016, 08:20 AM   #1
Total Bliss's Avatar
Porch and outside stair lights
Porch and stair lights went out together. Checked fuses in front compartment storage...ok. Did not check bulbs, don't think they would go out at the same time. Any suggestions?
2016 Silverado Dually
2016 Cedar Creek Champagne 38el
Total Bliss is offline   Reply With Quote
Old 08-19-2016, 08:28 AM   #2
SeaDog's Avatar
It sounds to me like you may have lost the ground or power wire, check the connections behind the switch the power may have come loose
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-20-2016, 09:10 AM   #3
the remote that came with my 38ck has porch light. What and where are the porch lights?
CTGREG is offline   Reply With Quote
Old 08-20-2016, 02:51 PM   #4
Members
Tommy Joann's Avatar
The porch light is that yellow light on the side of your RV near the entrance.
2015 Flagstaff 8528CKWSA Diamond Package
2015 Chevy Silverado Crew Cab LT
Husky 16K W Hitch w/ Husky 10-16 Composite Glider
Reese Revolution Pin Box
Tommy Joann is offline   Reply With Quote
Old 08-20-2016, 04:00 PM   #5
ttanous's Avatar
Also if you have a light on the stairs outside. Ours turns this on also.
ttanous is offline   Reply With Quote
Old 08-21-2016, 09:31 AM   #6
The awesome techs at the rally found the problem. Porch light above the door had a bad bulb. The light down by the stairs had a pinched wire. What made it confusing was they both went out at the same time. Something to add to an electric problem investigation.
light
