Old 08-21-2016, 04:38 PM   #1
jmh
Porch lights and slide outs
Installed led strip under awning today. When testing light I touched the one wire to socket of porch light. This made porch light, and step light go out. Went to put in slides and won't go in from button in panel but will work from button in basement. Are these two connected or just a coincidence.
jmh is offline   Reply With Quote
Old 08-22-2016, 09:55 AM   #2
Head Rambler
You most likely blew a fuse in the monitor/control panel. I'd check all the fuses.
Gotta go campin!
Old 08-22-2016, 03:33 PM   #3
jmh
All fuses good. Did notice the on/ switch is in the middle. Not up or down. Is it possible the switch blew with 12 volts
Old 08-22-2016, 03:34 PM   #4
jmh
By the way I can't reset the switch.
Old 08-22-2016, 04:02 PM   #5
Head Rambler
It's definitely possible that the switch is bad.
Gotta go campin!
Old 08-22-2016, 04:05 PM   #6
jmh
Thank you. I hope so
light, slide, slide out
