Old 06-18-2014, 08:57 PM   #1
Propane tank size...(another newbie question...)
Evening All,
Just wondered if it's possible to change the propane tanks in our 34rlsa from 30 pounders to 40 pounders?
One of the reasons we bought this unit is that it was set up with 2 solar panels, 4 6 volts and a 5500 cummins generator but it sure uses propane!
lJ
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 06-19-2014, 06:20 PM   #2
Campingnut's Avatar
I have spent a little time looking, and I can not see a way to change the tank size to 40lbs bottles without modifying the frame and I am not about to that. I asked the factory rep when I was having mine built if there was a way to put 40lbs bottles in my trailer but was told no.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 06-23-2014, 03:47 AM   #3
Plain Old Member
Not sure how the CC's are, but there is no way they'd fit in the Silverback. It's a tight fit to get the 30's in there. Crappy design really, compared to the nice slide out trays I had before on SOB.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
newbie, propane, tank
