01-05-2018, 07:41 PM
Pulling 5er with new 2017 Ford Super Duty
Any 2017 Ford guys out the pulling a CC standard 5th wheel camper. I asking about the camper to top of truck bed clearance. It’s appears to be really close. My first time pulling with new truck. Any suggestions?
01-05-2018, 07:48 PM
Mine is closer than that with no issues
If not camping, I am Sailing
I recommend about 6 inches. That gives good clearance to turn in at an offset drive.
01-05-2018, 07:49 PM
Some hitches can be adjusted higher and lower. Most come at the lowest setting.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
01-05-2018, 08:19 PM
Raise your hitch if you can. It is hard to tell from your pic but you RV looks a little nose low. I had to raise my hitch to the highest setting.
01-05-2018, 08:36 PM
I agree with dalford. Looks like you could stand raising the hitch 1 setting.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
01-05-2018, 10:43 PM
The hitch is a Ford factory installed “Reese “ custom 27.5k hitch. I’ll look again but I think, no adjust.
01-05-2018, 10:54 PM
If the hitch can't be adjusted, drop the pin box a notch. BTW, I've never seen a hitch that couldn't be adjusted. You really should try for 6" clearance.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
01-05-2018, 11:16 PM
It definitely can be adjusted. I have the same hitch. Had to raise it one hole to get the trailer level. Now I am one inch nose high measured at front of trailer vs rear - as level as it can get. You should be nearly level with 7+" clearance. I am 7.5" with CC 38EL, 2017 F-350 Dually & Reese 27.5k hitch with ford factory hitch puck mounts.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
01-05-2018, 11:24 PM
Ret E-9 Anchor-clanker
Sweet looking rig..
01-06-2018, 01:17 AM
Boatdude62 That is a beautiful rig.
01-06-2018, 01:39 AM
Thanks for the kind comments. I hope your right on adjustment, I’ll have a look.
01-06-2018, 06:02 AM
"On the road again"
We pull a 41' Cardinal with our truck exactly like yours (except black). The hitch was adjusted to the lowest position and made the clearance worrisome and the nose of the RV low. I raised the hitch position two slots and now it's pretty much perfectly level and I have about 7" clearance above the tailgate and rails.
Page 4 of the document in the link below shows the adjustment holes for your hitch I believe.
http://www.hitchpro.com/Application/...ons/N30142.pdf
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
01-06-2018, 01:24 PM
Raise it it's a must some time you will run in some campground that are not quite levelled. It could bend like a quite a lot. Having had to repair my PU box let me tell you it cost a lot of money.
01-06-2018, 01:51 PM
6" is considered the minimum. If you can go to more clearance and still tow reasonably level then do it. Never know when you will encounter a driveway with a drainage dip in it. If you ever intend to boondock with it then I would definitely shoot for more than 6" of clearance. Usually the roads in the national forests and parks are somewhat elevated.
2018 Chevrolet 3500HD CCSBSRW
Duramax/Allison
Demco 18k Autoslide
2012 Puma Unleashed 356QLB toy hauler
Toys - CRF250X, CRF250R, CRF450R, TTR230, TRX250EX, STX-1500 jet ski
01-06-2018, 01:52 PM
Georgia Rally Coordinator
Yes need to raise or going over and down a hump can cause the camper to hit the truck bed. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
01-06-2018, 02:15 PM
That was my concern. I would be very upset if I damage this truck. Glad I asked about this, it looked like I can raise it, as has been explained. Whew, every inch matters, right. That will help the camper also, is looked a little low in the front. I was nervous about the front level jacks also.
01-06-2018, 03:11 PM
clearance
at the very least 6 inches!!!!Ya don't wanna screw up your bed...
Save a beer for me!!! Happy Trails....Be Safe....
01-06-2018, 03:56 PM
I should have read the instructions, did not know about adjustable locations.
01-06-2018, 03:59 PM
