Old 06-28-2016, 05:26 PM   #11
Stevemc's Avatar
Originally Posted by dalford View Post
After you push the front 10 times and then rear 10 times you are supposed to press "Enter" button to set. See steps 4 and 5 below..
From the manual:
1. Manually run the jacks to level the unit. This is best achieved by placing a level in the center of the unit and leveling it both front to back and then side to side. (See “Basic Jack Operation” for instructions on how to manually operate the system).
2. Once the unit is level, turn off the touch pad.
3. With the touch pad off, press and release the “FRONT” button (Fig. 1G) ten (10) times and then press
and release the “REAR” button (Fig. 1J) ten (10) times.
4. The touch pad will flash and beep and the display will read “ZERO POINT CALIBRATION ENTER to set, Power to Exit” (Fig. 5).
5. To set the current position as the zero point, press the “ENTER” button (Fig. 1C).
Exactly what I did but it never beeps or says ZERO POINT CALIBRATION as stated in step 4.
Thanks for the input but like I said in the OP I have the manual.
Stevemc is offline   Reply With Quote
Old 06-28-2016, 07:48 PM   #12
padcarroll
Make sure the manual covers your model. FR delivered the wrong manuals with my Legacy. It wouldn't surprise me if you have the wrong manual as well.
Dave and Pam Carroll
Callie - 9 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 06-28-2016, 08:53 PM   #13
OK, here is from the Lippert Component Manual that covers all components of the Lippert Frame, axles, slides and level up..
It is a little different in that it says to level after the 20 button presses..
Maybe the unit has to be un-level before you begin? Maybe if it is already level the system is thinking there is nothing to do... Just a thought.. Start out of level by raising the front..
ZERO SETTING THE CONTROL
NOTE: Middle stabilizers are not used in this process. 1. Turn “ON/OFF” button “OFF”
2. Push“FRONT”button10times,
3. Push “REAR” button 10 times
4. Control will flash and beep, LCD says “ZERO POINT CALIBRATE”
5. Manually operate the jacks to attain unit level condition (use carpenter’s level). 6. To memorize this level condition , press “ENTER”
7. LCDsays“ZEROPOINTSTABILITYSUCCESSFULLYSET”
8. The control will then turn off.
9. Turn “ON/OFF” on to commence operation.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-28-2016, 09:27 PM   #14
junebug39's Avatar
https://youtu.be/XHmprBRfnJ8
Cedar Creek 2017 Silver Back 35IN
2011 Dodge Diesel Cummins 2500
junebug39 is offline   Reply With Quote
