Old 06-28-2016, 08:51 AM   #1
Stevemc's Avatar
Re-zeroing the Level Up system
Has anyone Re-zeroing their Level Up? Ours is a little off so I tried re-zeroing it this morning. I adjusted it manually to get it level. Then per the Level Up manual I pushed the on/off switch to off, pushed the front button 10 times, then the rear button 10 times and walla, nothing happens. The manual says it's supposed to beep and reset to zero. What am I missing?
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 06-28-2016, 09:34 AM   #2
bubbles's Avatar
Once you level it manually turn off and then turn back on and do procedure to start the re-zeroing process.
Old 06-28-2016, 11:57 AM   #3
DKRITTER's Avatar
It works but it's a funky little dance to get right.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is offline   Reply With Quote
Old 06-28-2016, 12:27 PM   #4
Stevemc's Avatar
How do you keep the raising when you push the front button 10 times?
Steve & Jean
Furbaby - T.J.
Old 06-28-2016, 01:13 PM   #5
DKRITTER's Avatar
One note, I downloaded the Lippert Android app from the play store some time ago and it has verry good instructions on all of their products.
Comes in handy for stuff like this.
Old 06-28-2016, 01:34 PM   #6
mlwilliams808's Avatar
Level unit then turn off level up then push the front & rear buttons
mlwilliams808 is offline   Reply With Quote
Old 06-28-2016, 01:55 PM   #7
NMWildcat's Avatar
I found the timing of pushing the buttons matters also. I tried to deliberately hit the button 10 times but I guess I was a little slow. It only works when I hit the button 10 times fast... no pause....
Good luck!
Scott and Liz - Southern NM
Old 06-28-2016, 03:17 PM   #8
bubbles's Avatar
This may be wrong for your system. What you did was per the manual so don't know why it failed. Sometimes our manuals leave out a vital step. Press on.
Old 06-28-2016, 04:47 PM   #9
After you push the front 10 times and then rear 10 times you are supposed to press "Enter" button to set. See steps 4 and 5 below..
From the manual:
1. Manually run the jacks to level the unit. This is best achieved by placing a level in the center of the unit and leveling it both front to back and then side to side. (See “Basic Jack Operation” for instructions on how to manually operate the system).
2. Once the unit is level, turn off the touch pad.
3. With the touch pad off, press and release the “FRONT” button (Fig. 1G) ten (10) times and then press
and release the “REAR” button (Fig. 1J) ten (10) times.
4. The touch pad will flash and beep and the display will read “ZERO POINT CALIBRATION ENTER to set, Power to Exit” (Fig. 5).
5. To set the current position as the zero point, press the “ENTER” button (Fig. 1C).
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 06-28-2016, 05:14 PM   #10
Stevemc's Avatar
That's what I tried first per the manual but nothing happens.
