Old 12-13-2015, 12:41 PM   #1
Jesse's Avatar
Real Newby, Pre-Purchase Question on Weight
Recently purchased a new King Ranch F250 4x4 6.7L Diesel SRW, it can handle 15,100 lbs with fifth wheel hauling. I am wishing to purchase a Silverback 37RL at 12,830 lbs. With all extra weight added, we are looking at towing about 13,800 lbs. Respectfully from you seasoned haulers, does this seem ok with the weight? Many Thanks!
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 12-13-2015, 12:47 PM   #2
Kenny kustom's Avatar
For sure!!
You will be under your towing, but likely over the gvwr rated sticker on your door.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-13-2015, 01:32 PM   #3
asquared's Avatar
You will likely be over your Gvwr. Best thing to do is go weigh your truck with full tank of fuel and all passengers, pets and gear you plan to have in it when towing. If you go to a catscale, Weigh your front axle on scale pad one and rear axle on scale pad two. This will allow you to get a total truck weight and each axle weight. Subtract the total truck weight from your gcwr to get your adjusted towing capacity. Subtract your total truck weight from your Gvwr to get your available payload. Subtract your rear axle weight from your GRAWR to get your available rear axle capacity. The loaded weight of the fiver needs to be within the adjusted towing capacity. The loaded pin weight of the fiver needs to be within your available rear axle capacity and within your available payload. Ideal pin weight will be 10-25% of loaded fiver weight, most average closer to 20%. Most typically add around 1000-1500 lbs to their trailers. Although doing your calculations using fiver Gvwr is by far the safest though you will not likely be at max capacity. Also if you don't have a hitch in your truck bed yet, you can add approx 150 lbs for that.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 12-13-2015, 08:00 PM   #4
Former Full Timer
Duckogram's Avatar
All of the above and then there is your tire (rear specifically) load carrying capacity. If you have 17" wheels they are E load range. Add your truck rear axle weight loaded with all aboard and your pin weight with the Silverback ready to go including your DW's shoe collection and if your rubber does not exceed that number you will be in an unsafe situation.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 12-13-2015, 08:53 PM   #5
Jesse's Avatar
Thanks for all the great info.
Jesse
2016 F450
Old 12-13-2015, 08:54 PM   #6
ttanous's Avatar
Jesse here is what I found. You should be good on the combined weight. Click image for larger version
Name:	ImageUploadedByForest River Forums1450061674.007982.jpg
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 12-13-2015, 09:35 PM   #7
asquared's Avatar
Originally Posted by ttanous View Post
Jesse here is what I found. You should be good on the combined weight. Attachment 96158
Tom & Marilyn
Just remember, it is about more than just combined weight. Each and every option on your truck takes away from posted payloads and towing capacities as does the hitch, passengers, pets and anything else you stick in or on your truck.
2014 Sabre 34REQS-6
Old 12-13-2015, 10:27 PM   #8
You have a KR. One of the highest trim.
Go stick it on a scale.
Only way to know for sure.
When I had my ram 2500. I had a family of four in the truck and went over the scale at the airport.
We only had 800 lbs of payload left.
That's with no trailer.
2016 Sabre 36QBOK
I am nice!
Old 12-14-2015, 08:45 AM   #9
Busybeavers's Avatar
When we purchased our Silverback 29RE at a show, the dry weight sticker on that model showed 10,356 lbs. When ours arrived I was shocked at the new dry weight, with the added front A/C, and double pane windows, my dry weight came in at 11,250 lbs. 900 lbs for the added two options. If you are ordering with options, your dry weight at 12,830 maybe a lot more. Also, on a F250, pin weight my be something else you may want to watch.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 12-14-2015, 01:08 PM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
After scales and stickers, its really all about available Payload. For the 250s and 2500s its 10,000 pounds minus the trucks combined scale weight when loaded with passengers, fuel, hitch in the bed and the family's "stuff". Example, my 2015 2500 has a sticker Payload available 2,519#, after scaling as described, the 10000# delta is 1,994#.
My 5th wheel tow capability has plenty of room, so I looked to the Rear Axle and tire capabilities, doing that I have more truck rear payload room. With that method, I just had to make sure I didn't get a 5th wheel where my tongue weight was less than the 10% to 25% safety factor.
Bottom line, I'm barely within my truck scaled payload availability, but I'm comfortable with the margin of closeness based upon better measures on RAWR and trailer pin weight.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
weight
