Old 03-11-2015, 04:22 PM   #1
Rear receiver for bike rack
Hello, I'm looking to mount a receiver on the back of a 2015 32rl. My dealer is of no help on this. I know it was an option on this model, there are two plates welded on the frame with bolt holes installed. Does anyone have this option or know brand/part # ? Thanks.
phred is offline   Reply With Quote
Old 03-11-2015, 04:29 PM   #2
Certified Curmudgeon
You are better off without the factory receiver as it is rated for 50# according to those that have one. A local hitch shop is a better bet.
Mike Dropped
Old 03-11-2015, 04:35 PM   #3
Duckogram is correct the Factory receiver is not good for anything really, Any bike rack that will fit into the class II receiver is likely to bounce all over the place.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 03-11-2015, 05:24 PM   #4
I have the same model, 50 pounds, what a joke.
spock123 is offline   Reply With Quote
Old 03-12-2015, 07:52 AM   #5
Oakman's Avatar
I must have a better hitch on the back of my 29RL Silverback. Mine has a 150 pound capacity.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-12-2015, 08:08 AM   #6
My 2015 29 RE Silverback has the same sticker on the hitch as Oakman's. 150 lb capacity. We carry 2 bikes. Seems to be fine. I typically run a bungee cord from one of the bikes to the ladder to act a a shock absorber to reduce any wiggle.
I think the hitch is intended for bike racks, not towing. A capacity of 150 lbs should be sufficient for that purpose. I wouldn't put a platform with a generator on it, but for bikes it works.
2 for the road is offline   Reply With Quote
Old 03-12-2015, 08:29 AM   #7
vinmaker's Avatar
You can also get a receiver hitch mounted to the frame. E-trailer has RV receiver hitches that can simply be bolted to the frame. Just measure what width you need.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 03-12-2015, 12:57 PM   #8
2007 WildCat 32QBBS
18CrewDually's Avatar
Have a fabrication shop add a receiver. Here are some kits:
http://www.etrailer.com/dept-pg-Spec...r_Hitches.aspx
18CrewDually is offline   Reply With Quote
Old 03-12-2015, 04:46 PM   #9
Ditto -- 150 lb limit per the sticker on my 2014 29RE. I haven't used it ... put one bike in the bed of the pickup and the other lays on the bed when we're moving.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 03-12-2015, 04:48 PM   #10
vinmaker's Avatar
This is what I was thinking for you to use.
Adjustable Width Trailer Hitch Receiver for RVs, 22" to 72" Wide Curt Specialty Trailer Hitches 13703
Vin.
2015 HW296
2013 Chevy Tahoe
Old 03-13-2015, 06:41 AM   #11
Originally Posted by vinmaker View Post
Thanks. I will look at that
Old 03-13-2015, 02:07 PM   #12
I have used mine and it shows the 150 lbs limit and it worked fine. I drove 6000 miles this past summer with two adult mountain bikes. While there is bounce because i noticed paint wear on the bike frames just make sure everything is really tight and buy a quality bike rack.
SKGCRD is offline   Reply With Quote
bike, bike rack
