Old 09-16-2013, 10:16 PM   #1
OL Creeker's Avatar
Receiver
Has anyone had a receiver installed? I'm thinking about adding one of those racks to carry DW's exerciser.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 09-17-2013, 07:48 AM   #2
You mean like on the rear frame/bumper? Doing so will void your frame warranty.
Old 09-17-2013, 09:20 AM   #3
Denver, CO
garbonz's Avatar
If it ain't there already, your rear frame ain't designed for it. The I beams in these current models do not have much reserve strength.. Some units have a rear rack that are specifically design to hold a load on the back...
2017 Fuse 23T
Old 09-17-2013, 04:29 PM   #4
Former Full Timer
Duckogram's Avatar
The answer is yeah but...
I have the factory 2". Probably the last one. They are 1.5's now. If your dealer can't/won't, I suggest you send "mikey" a PM. As far as voiding the warranty... I don't think so. It's a Cedar Creek.
What you can't do is tow with it. That will
cause consternation.
If all the above does not get you where you want to be, I suggest you call the folks in Shipshe for a remedy. I'm almost certain that the folks at Interstate RV can do it for you with CC blessings.
Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 09-17-2013, 05:39 PM   #5
TURBS's Avatar
I have had a receiver on the back of my tt flagstaff when I had it.
Lets just say that it last one trip and off it came.
The rack bounced so violently that it ruined the back of my trailer.
Unless its a factory installed rack I'd run very very far from this idea.
Old 09-17-2013, 05:51 PM   #6
Former Full Timer
Duckogram's Avatar
Turbs, Turbs, Turbs,
Newer Creeks don't have no "stinking tube" bumper. Receivers are frame mounted.
I had a Curt bumper mount on my Bullet and it bounced the bikes severely.
No bounce with this one however I did do some permanent shimming.
Old 09-17-2013, 06:01 PM   #7
TURBS's Avatar
Mine wasnt tube either.
Pic is an example and not my actual unit it was for dramtic affect.
My bumper was mounted to a "fabricated" 6" I beam.
Old 09-17-2013, 10:11 PM   #8
OL Creeker's Avatar
A rear receiver
Apparently, a 1 1/2" receiver is available from FR for the CC. Therefore, it will not void the warranty. That means I can have one that size installed anywhere without warranty interference. I want to be able to use a platform cargo carrier.
Duramax/Allison
Old 09-18-2013, 08:14 AM   #9
You are assuming facts not in evidence. It may be "available" as a replacement for those that came with it originally. If you think it won't void the warranty, you should get that in writing from FR, or have a dealer do it and make sure they understand that you don't want them to void the warranty.
Old 09-18-2013, 10:08 AM   #10
Denver, CO
garbonz's Avatar
X2. Unless you know your model is identical, which it well may be, I would make SURE it is designed for the additional add on and weight...
2017 Fuse 23T
