Old 03-12-2016, 05:28 PM   #11
And you will never fit an entire pizza box into that 13 cu. ft. model.......
Go BIG.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 03-12-2016, 06:37 PM   #12
ttanous's Avatar
Good catch dieselguy!
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 03-12-2016, 06:54 PM   #13
Kenny kustom's Avatar
Go BIG.
Good luck,
Don
No need after I'm done!! Lol!!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-12-2016, 06:55 PM   #14
I not sure how many times this has to be posted but your residential refer will do fine while running down the road. The refer is being powered thru the converter and you vehicle engines alternator is keeping the battery charged. My Cardinal only had one 12 volt battery and it would keep the refer running for 48 hours if not plugged into the truck or the campground. My new motorhome has 4 12 volt batteries and it will run for four days off just the batteries. Again while you are driving it is running off the engines alternator.
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 03-13-2016, 02:21 PM   #15
keith52's Avatar
Go BIG.
Good luck,
Don
If you fold the box in half and secure it with duct tape, it fits just fine in a 13 cu. ft. model.
keith52 is offline   Reply With Quote
Old 03-13-2016, 03:38 PM   #16
"The refer is being powered thru the converter and you vehicle engines alternator is keeping the battery charged." Our 20 cu ft fridge runs off the inverter, which is powered by four 6 volt batteries (connected in series and parallel), which is recharged by the truck alternator as we go down the highway. In two hours the fridge goes from room temp to 38 degrees in the fridge, 0 degrees in the freezer and stays that way till turned off. The four best things on our CC is the bed, bathroom, A/C's and the fridge.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 03-13-2016, 04:21 PM   #17
BandJCarm's Avatar
Originally Posted by dieselguy View Post
BandJCarm ... note that ttanous has four 6 volt batteries to draw power from ... a single 12 volt or even two twelve volts
may not supply the stated 14+ hours of service.
Four sixes would have to be two in series, and the coupling in parallel, to get 12 v.
Why not four 12v full size batteries all in parallel?
BandJCarm is offline   Reply With Quote
Old 03-13-2016, 04:33 PM   #18
The_Rhino's Avatar
btritschler1437, what brand/model of refrigerator & inverter do you have?
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 03-13-2016, 08:03 PM   #19
Regarding battery configurations, the more batteries in series the better for the batteries. 6 volt batteries have more watt hours than 12 volt batteries for the same size. Check the battery labels. It would be best to have 4 3-volt batteries in series.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 03-13-2016, 08:28 PM   #20
Lifeline has 2volt batteries.
900ah
2016 Sabre 36QBOK
