Old 08-22-2016, 09:28 PM   #11
kenandterry's Avatar
The fridge works using 12 volts when running on propane.
Do you have a meter to measure your battery output?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-22-2016, 09:42 PM   #12
Measure it in morning and evening. 12.8
Sent from my SCH-I545 using Tapatalk
Whitegirl24 is offline   Reply With Quote
Old 08-22-2016, 11:10 PM   #13
Originally Posted by Whitegirl24 View Post
Our refregiator runs off of propane not electric. The pilot goes out in the early morning and then it takes a few times for it to light. It only goes off during the nigt.
How do you know? Do you get a check LED? The pilot light is the the light. There is nothing more than a pilot light to heat the element. Maybe it is at temp and does not need to be on because the fridge is at temp.
What do you do to make it light that takes several attempts. Who is watching the pilot light during this time?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-22-2016, 11:27 PM   #14
The check light on the refregiator comes on to let you know that it's not on. Turn it off and back on and you can hear the pilot trying to lite. Do these several times and it will finally light.
Old 08-23-2016, 12:08 AM   #15
That makes sense. You do this before you run the generator?
2016 Siverback 33IK
Old 08-23-2016, 12:12 AM   #16
Check out this site.. I have a Dometic refrigerator model DM2652 when I go to higher
2016 Siverback 33IK
Old 08-23-2016, 08:21 AM   #17
97flhtcui's Avatar
Your propane regulator may be freezing up.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
97flhtcui is offline   Reply With Quote
Old 08-23-2016, 08:49 AM   #18
Pickin' & Campin'
Have you tried to light any other propane appliances when you are experiencing the problem with your refrigerator? Such as... will the stove light?
Just trying to determine if it is a control problem or a propane supply problem.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
2017 Ford F-Series SCREW 4x4
Days Camped: '15=22 '16=46 '17=30
Old 08-23-2016, 10:16 AM   #19
We have and the stove works it's just the refrigerator.
Old 08-23-2016, 11:32 AM   #20
fonzie's Avatar
To make sure it is not regulator freezing, you would have to try stove as soon as refrigerator acts up (shuts down) as regulator will defrost once propane stops flowing and will resume normal function.....
Fonzie
refrigerator
