Old 03-15-2016, 09:19 PM   #1
Removing Jensen TV from bracket
I'm sure that someone has asked this before. I have a 33RL 2015 Silverback and I have tried everything short of breaking something to remove the TV from the bracket. There is very little room and you can't see behind. Can anyone give me a hint. Thanks
Doug Currie is online now   Reply With Quote
Old 03-15-2016, 09:27 PM   #2
should have found a very long allen key in the trailer. there are 2 allen screws on each side holding the two parts of the mounting bracket. use a flashlight and mirror to find them. it really is kind of hard but i have had mine off twice. they come in from the sides.
05 gmc duramax cc sb
11 silverback 31b2
skidoonut is offline   Reply With Quote
Old 03-15-2016, 10:14 PM   #3
Thank for your help. I'll give that a try. Appreciate it.
Old 03-16-2016, 08:42 AM   #4
steelpony5555's Avatar
Hmmmmm mine is just on 4 lugs...have to pop it straight up bout an inch and then out....don't have any allen screws on mine...
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 03-16-2016, 09:29 AM   #5
Same on my 2016 33IK ... a little tough, but pops straight up off wall mount.
dieselguy is offline   Reply With Quote
Old 03-16-2016, 09:43 AM   #6
Sounds like they are using different mounting methods. Forest river service just got back to me and said there is a plastic button on each side that needs to be pressed past the metal and then it pops out. I'll let you all know this weekend when I try mine again.
Old 03-16-2016, 09:57 AM   #7
acadianbob's Avatar
This is all very interesting as I'll want to be doing this as well. Please continue to post what you find.
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-16-2016, 11:36 AM   #8
7 Year Class A RV'er
Mine has the Allen screws, one each side at the bottom. Loosen them, tilt the bottom out and lift off the bracket.
2015 Legacy SR340 360RB
conceptumator is online now   Reply With Quote
Old 03-16-2016, 02:27 PM   #9
Nick M's Avatar
Mine are at the top
I have a Jensen bracket but previous owner changed the Jensen tv to an LG
My tv bracket hangs on two horizontal parallel rods about 16" apart. The top rod has an angle iron piece across the top rod that is secured by two screws, one in each end at the top and behind the tv. Had to use a mirror and flashlight to figure it out. The screws are socket head cap screws with lock washers. The angle piece keeps the top of the tv hanger secure on the rods. I keep the cap screws finger tight, I'd never find them with an Allen wrench.
The other 2 brackets in my fiver have a chain that releases the tv mount latch. Much easier to deal with.
Nick, Sharon and Finnigan
Nick M is offline   Reply With Quote
Old 03-19-2016, 11:55 AM   #10
I did say I get back after checking out my TV mount. Well its different than FR said it would be. It's same as steelpony5555 said. Heres a pic
