Old 03-02-2016, 03:06 PM   #1
Stevemc's Avatar
Removing rear clearance lights
We have a 2013 36ckts and I would like to install a rear camera that wires into the clearence lights on the back of the trailer. The lights have a thick rubber seal around them and no screws showing. I think they just push in and the rubber seal keeps them in but how do you get them out? I am reluctant to pry with a screwdriver. I have body paint and don't want to scar it around the light. Is there any secret to getting these lights out?
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 03-02-2016, 03:55 PM   #2
Rest and Relax's Avatar
They just pop out like a tractor trailer's sometimes they are a bit hard to get out just spray them with some kind of lubricant
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 03-05-2016, 01:17 PM   #3
Mddle of the Rd Extremist
MeepMeep's Avatar
Just like Rest and Relax said....they just pop out. You may need to be "gently" persuasive, depending....
Name:	2014 CC  (64).jpg
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 03-05-2016, 06:40 PM   #4
Stevemc's Avatar
Thanks for the advice. There just isn't much to get a hold of to pull them out.
Steve & Jean
Furbaby - T.J.
Old 03-12-2016, 07:25 AM   #5
My camera came with a rubber grommet and instructions to drill a hole for the wires. I drilled between the left and center lights and pulled the existing wires out of the hole with needle nose pliers. There was enough slack in the wires to work with them. No need to pull the clearance light fixtures out.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 03-12-2016, 07:28 AM   #6
Stevemc's Avatar
What brand camera do you have? Thanks
Old 03-12-2016, 04:15 PM   #7
Pretty sure it is a Voyager. I'll check later, if I can.
Old 03-12-2016, 07:35 PM   #8
Yup. It's a Voyager. About $500.00, I believe.
Old 03-12-2016, 08:18 PM   #9
Stevemc's Avatar
Steve & Jean
Furbaby - T.J.
light
