Old 01-16-2019, 08:48 AM   #1
Removing wall
Can I remove the dividing wall between living and kitchen? What will it look like on the floor under it and against the wall? What is the best way to take it out? 2017 CC silverback 37RL.
Thank you for the help. Click image for larger version
ID:	194703Click image for larger version
bedelstein is offline   Reply With Quote
Old 01-16-2019, 09:11 AM   #2
cavie's Avatar
Shouldn't be a problem. I haven't done it but otheres have. You should find floor and wall covering under it. A few screw holes to plug. Nothing a creative mind can't fix.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-16-2019, 09:13 AM   #3
Thank you
Old 01-16-2019, 09:31 AM   #4
PPST Wannabe
kenandterry's Avatar
I see what you’re proposing in removing this wall.
However, Cavie used the words “shouldn’t” and “should”.
Don’t take that as a guarantee.
YMMV.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-16-2019, 09:38 AM   #5
YMMV.
Thank you, it's why I'm asking the group.
Old 01-16-2019, 01:21 PM   #6
Head Rambler
Just be aware that some are screwed in, in ways that make you go huh!
Like from outside the wall in, and from below through the floor. In cases where you can't get to the head of the screw, it's usually best to use an oscillating saw with an abrasive blade and just saw the screw off. Be careful not to scratch the surrounding surfaces.
Gotta go campin!
Old 01-16-2019, 08:07 PM   #7
Thank you
