Old 12-23-2014, 08:51 PM   #1
Replacement of light bulbs
I own a 2014 CC 36 CKTS. I need to replace a bulb over the dining room table. I removed the bulb but did not find any identifying marking on the bulb. Need some help!
dennismartin is offline   Reply With Quote
Old 12-23-2014, 08:58 PM   #2
mark0224's Avatar
post a pic of the bulb it may help,without knowing your trailer I couldn't tell without seeing the bulb.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 12-24-2014, 08:44 AM   #3
That's why I replaced the sockets and bulbs with 1076 type 15d LED bulbs & sockets. You don't want incandescent bulbs there.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 12-24-2014, 11:25 AM   #4
Name:   ImageUploadedByForest River Forums1419441877.227787.jpg
Bulb picture
Old 12-24-2014, 11:37 AM   #5
bulb number is 921.
05 gmc duramax cc sb
11 silverback 31b2
skidoonut is offline   Reply With Quote
Old 12-24-2014, 12:06 PM   #6
Completely agree that it appears to be a 921, although it is a little hard to tell the length from the picture.
One thing to consider is replacing with an LED. They use a ton less energy and seem to be a brighter more natural light. I replaced all of my bulbs with LED equivalents. Now I can turn on every light in the TT and the convertor fan doesn't even run.
The LEDs will last much, much longer too.
I found good prices for LEDs on Amazon. Just search 921 LED replacement.
Good luck!
rabreen is offline   Reply With Quote
Old 12-24-2014, 01:07 PM   #7
camaraderie's Avatar
x2 on the 921 and LED replacement recommendation.
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 12-24-2014, 01:26 PM   #8
BooBoo23's Avatar
Just search on Ebay for a "921 LED Bulb" for a replacement. It will have a "T10" wedge base. Shop around and try to find one that is at least 200 lumens in brightness and either a "warm white" color which is a soft light or a "natural/bright white" which may be a little too bright in some cases. Prices vary so look around. Anywhere from .50 each to over $5.00 each. Check the length to make sure it will fit. Some will be like a flat disk with around 20 LEDs on the surface or some will be cylindrical with the LEDs mounted around the outside. A dome light replacement is usually not too critical in length.
Get rid of those filament bulbs, they get to hot and use a lot of power.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23
Camped 2015 - 47
Camped 2016 - 51 done - 6 more planned so far
BooBoo23 is offline   Reply With Quote
Old 12-24-2014, 01:46 PM   #9
Originally Posted by skidoonut View Post
bulb number is 921.
921's should be a T10 LED base.
bradleyr001 is offline   Reply With Quote
Old 12-24-2014, 01:53 PM   #10
You need to be careful on the brightness comments. LED's use less power, which is a good thing when off the grid, but their brightness, more times than not, will be dimmer. You need to pay attention to the SMD chips (little yellow/white things) on the board. Currently there are three sizes of SMD's. The higher the number designation for the SMD, the more visible light it will emit. Multiply that by the number on the board, and the direction of light emmited, determines perceived visible light. One more point, there are two light designations commonly used, warm and bright. If you read up on this site and others you will get a quick education, if you decide to jump to LED.
light, replacement
