Old 08-22-2016, 02:24 PM   #21
Originally Posted by Bama Rambler View Post
The cables aren't that hard to change. If you have the enclosed underbelly, gaining access to the valves is the problem, and that isn't a huge problem depending on whether you want to cut a hole in it or not.
You can go to Valterra's site and download the instructions if you want to see how it's done.
I thought with the Cedar Creek all you had to do was take a panel off to get to the dump valves
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 10-29-2016, 01:41 PM   #22
Is anyone using a Valterra solid wire cable to operate a Bristol valve?
hercrat is offline   Reply With Quote
Old 10-29-2016, 03:14 PM   #23
How do you know if it's solid cable or not? We have a 2013 Forest River 337FB and when we tried to attach the drain hose to empty the tanks today, we found out the hard way that our waste water valve was leaking. EWWW! (I'm thanking the good Lord for my hubby who was there to handle that mess.)
The rod looks like it does not go all the way in at the panel.
Not sure what our next step should be. I'm starting to realize the value of hotels.
Ainyday is offline   Reply With Quote
Old 10-29-2016, 03:42 PM   #24
Valves
The Bristol cable drain valves are a braided wire while the Valterra is a solid cable.
Old 10-29-2016, 06:24 PM   #25
I just installed the Valterra electric black tank valve. Not cheap but tired of leaking cable operated valve.
ba964 is offline   Reply With Quote
Old 10-29-2016, 06:40 PM   #26
You should start out by installing a spin on valve at the end of the sewer connection. Very simple install you just twist it on where the sewer hose connects. With this installed you will never get another poop shower. It also will work as an emergency shut-off in the event a valve sticks open. Best $15.00 you can spend.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-29-2016, 07:53 PM   #27
MrNiceGuy's Avatar
Agree whole heartily with GOTTOYS. I will never go without the auxiliary valve on the holding tank connection.
https://www.amazon.com/Valterra-T58-.../dp/B000BGHYJS
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 10-29-2016, 07:57 PM   #28
The rod is not supposed to go all the way in. Should show about 1/4 inch or so.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
drain, valve
