Old 01-25-2016, 06:17 AM   #11
Originally Posted by keith52 View Post
Spock, just curious why you would need a 3000 watt inverter? From my research the inverter only powers the fridge and nothing else.
I need a bigger inverter for the refrigerator and it's one I already have. What I was thinking about doing was turning the battery disconnect off and plugging in my camper to have 120 volts, that way I could have the microwave on, plus the tv
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-27-2016, 09:09 PM   #12
97flhtcui's Avatar
4 6v batteries
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 01-28-2016, 12:39 PM   #13
seems that the factory uses group 27 12 volt batteries. My 335 with a residential reefer has 4 of them and a 2000 watt inverter. I would prefer 4-6 volt Trojans but will make the change when the ones I have die. I also added an additional 1000 watt inverter for the TVs, cell phones and my CPAP.
4 6 volt units are better for SOC and life but I won't spend the money and eliminate 4 good batteries.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 01-30-2016, 09:52 PM   #14
Pulled that wimpy single 12 volt marine battery and put it in the boat. Trojans only way to go, get the watering kit too
Brentf is offline   Reply With Quote
Old 02-01-2016, 04:20 PM   #15
I got four 6 Volt Interstate batteries, but they were not properly wired. Only one pair were getting charged.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-01-2016, 08:05 PM   #16
dealer installed 2 12v but wouldn't keep up with residential fridg. Now installing 4 6volts.
Mahlstedtd is offline   Reply With Quote
Old 02-01-2016, 08:12 PM   #17
TURBS's Avatar
Wouldn't keep up going down the road?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-01-2016, 08:35 PM   #18
The Silverback 29RE does not have space for four 6 volt batteries. The dealer installed two 12 volt batteries, but did not wire them correctly. I didn't figure that out until I got it home. Several threads on here addressing that issue. I did add a third 12 volt of the exact same brand and size in parallel with the other two. The residential refer will run all day on the inverter with no issues. We are really happy with the residential refer.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-01-2016, 08:36 PM   #19
Yes. Inverter kept turning off after a few hrs of driving.
Old 02-01-2016, 08:39 PM   #20
I guess I'm lucky this far. I have one 12v battery and a residential refer. Now it is not a side by side but I have never had the inverter not keep up with the fridge. I have had 14 hour days with stops for over 2 hours (tv not running). I know it keeps up because I check it every time I stop.
I plan on adding another battery (not sure why) but it makes sense if I ever go longer...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
fridge
