Old 02-01-2016, 08:42 PM   #21
Originally Posted by Mahlstedtd View Post
Yes. Inverter kept turning off after a few hrs of driving.
Wow, would it restart? A few hours really sounds short. Like I've said, 14 hours and no problem, one 12v battery...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 02-01-2016, 09:02 PM   #22
We would unplug fridge and then turn inverter back on. A few hrs later same thing.
Mahlstedtd is offline   Reply With Quote
Old 02-01-2016, 09:26 PM   #23
TURBS's Avatar
Residential Fridge
I'd likely say you have an issue.
My boss has a residential fridge with one group 27 battery, after ten hours it gets low but not dead.
Is your charge line from your tv working?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-01-2016, 09:29 PM   #24
When I bring my RV home for the next trip I am going to let it just run off of battery (no shore power charge, no tv) and see how long it runs...
I would suggest you check all your connections to your inverter and battery to make sure all are tight. If something is loose it could shut down and will not auto restart.
When you unplug the fridge do you rep lug and turn on inverter right away and then find it off again in several hours? Or do you have to wait some time before you can use it again? It seems if it comes right back on and then runs for several hours that you may have another issue than charge capacity, just saying...
2016 Siverback 33IK
Old 02-01-2016, 09:31 PM   #25
First they thought it was the TV but checked it . All ok. Then thought it was the inverter. Now they tell me it is because the trailer calls for 4-6volts and they only installed 2-12 volt.
Old 02-01-2016, 09:52 PM   #26
TURBS's Avatar
I don't buy it.
I'd get a second opinion.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-01-2016, 09:58 PM   #27
Originally Posted by TURBS View Post
I don't buy it.
2015 Columbus 320RS
2008 2500HD Duramax
X2
2016 Siverback 33IK
Old 02-01-2016, 10:03 PM   #28
VinceU's Avatar
Don't buy it either, inverter senses proper voltage both the same here. Current storage level is not available to the inverter. Both setups are sufficient for the task at hand.
Old 02-02-2016, 11:37 AM   #29
Originally Posted by keith52 View Post
.......... I know the sticker says 4 6volt batteries required, just wondering if different dealers pull different tricks..........
To what sticker are you referring?
phillyg is offline   Reply With Quote
Old 02-02-2016, 08:00 PM   #30
My 2016 31rk came with 2 12 volt series 24 batteries.
hughd033 is offline   Reply With Quote
fridge
