Old 02-03-2016, 08:00 AM   #31
Originally Posted by phillyg View Post
To what sticker are you referring?
There was a sticker on the wall of the battery compartment that showed the proper battery hookup diagram.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-03-2016, 03:07 PM   #32
keith52's Avatar
Just ordered a 36ckts yesterday at the Tulsa RV show. The one that they had at the show had 4 6volt batteries installed. The sticker stating that 4 6volt are required and showing the correct cable configuration was not in the compartment, or it was behind the batteries and not visible.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 02-03-2016, 03:14 PM   #33
I called Cedar Creek and told them there was not one on the battery box door and they sent me one
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 02-03-2016, 03:31 PM   #34
fwiw
4 batteries?
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-03-2016, 07:02 PM   #35
Me and the DW bought the 2015 36ckts . It has a label on the inside of the battery door showing 4-6 volt batteries and how they should be installed.
Mahlstedtd is offline   Reply With Quote
Old 02-04-2016, 07:31 AM   #36
My label is on the back wall of the battery compartment, so you cannot see it when the batteries are in the compartment.
Old 02-05-2016, 04:39 PM   #37
Busybeavers's Avatar
Sounds like another Dealer ripoff!
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 02-07-2016, 09:56 PM   #38
The only success I had was upgrading to a 2000 watt inverter. What batteries and set up I used didn't matter except to change the length of time the fridge would run when dry camping.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 02-09-2016, 02:42 PM   #39
keith52's Avatar
Sterlingsilver, are you saying that you had a problem with the fridge running trouble free with the standard 1000 watt inverter? Guess I don't understand why you needed to upgrade to a 2000 watt.
Old 02-09-2016, 02:52 PM   #40
I have a 1,000 watt inverter in my camper and it's not the inverter that's the problem. My batteries aren't the best, I think I'm going to have to change the batteries. I have four six volt batteries but they are only 105amp each. I plan to check them out on a little three week trip soon.
fridge
