Old 01-24-2016, 04:26 PM   #1
keith52's Avatar
Residential Fridge
Question for the folks with the residential fridge.
When you picked up your 5er from the dealer, either off the lot or factory ordered, what battery set up did you get? I know the sticker says 4 6volt batteries required, just wondering if different dealers pull different tricks. What did your 5er come with??
keith52 is offline   Reply With Quote
Old 01-24-2016, 04:49 PM   #2
Rest and Relax's Avatar
Dealer installed 4x12volt in my 38fb2
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 01-24-2016, 05:07 PM   #3
AquaMan's Avatar
Out GT came with 4 6volt batteries, which is the best way to go if you have a choice.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-24-2016, 05:11 PM   #4
Mine came with 4 12 volt batteries .
Georgetown XL 377TS
USAF-- CMSGT Retired.
georgew48 is offline   Reply With Quote
Old 01-24-2016, 06:08 PM   #5
Mine came with 4 6volt batteries but they were the cheapest the dealer could put in. I plan to put in 4 6volt Trojans in this year with a bigger inverter, camper came with a 1000 watt inverter. I plan to install a 3000 watt inverter
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-24-2016, 06:45 PM   #6
keith52's Avatar
Spock, just curious why you would need a 3000 watt inverter? From my research the inverter only powers the fridge and nothing else.
Old 01-24-2016, 06:55 PM   #7
ttanous's Avatar
My dealer installed 4 6 volt interstate batteries but that was the requirement for the deal. I believe they intended to install 4 6 volts. I just wanted to make sure they had been interstate.
ttanous is offline   Reply With Quote
Old 01-24-2016, 07:33 PM   #8
I had four six volt batteries as well. I was surprised because the other dealer I was shopping only included a single 12 volt.
guy.lawless is offline   Reply With Quote
Old 01-24-2016, 08:44 PM   #9
VinceU's Avatar
You need to seriously increase ampacity of all included cables as well, AC and DC.
Old 01-24-2016, 08:56 PM   #10
My dealer put in 1 12v in Aug. 2011 which was replaced Dec 2015. When the battery went bad with no warning. Not knowing any better I replaced it with 12v. After replacing battery found the converter was only putting out 9 v so replaced the convert also.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
fridge
