Old 06-03-2014, 02:33 PM   #11
I had the same problem. still don't work right. works good on 120 volt and when hooked up to the truck. batteries don't last long .soon as I stop goes into alarm
wire1946 is offline   Reply With Quote
Old 06-03-2014, 06:43 PM   #12
Originally Posted by Sterlingsilver View Post
Factory stock cables were 2 gauge. 1/0 is 2 sizes heavier. 1 gauge would probably have been OK but I wanted to use welding cable because it is more flexible and my supplier only had 1/0. Anyway, when it comes to battery cables more is better.
Sent from my DROID RAZR using Forest River Forums mobile app
Hmmm...maybe I should check mine and see what size they are.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 06-03-2014, 08:32 PM   #13
Check cable connections as others mentioned. Check battery charge. Cable connectors have to be well crimped and tightly bolted to the batteries. Voltage has to hold steady at the inverter input when the fridge starts.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
fridge, inverter
