Old 07-04-2019, 10:49 AM   #1
Residential Fridge shuts off during tow
Residential fridge does not run during towing. Inverter is on .
Cedar Creek Champagne 38ERK
Whatís wrong?
Johite is offline   Reply With Quote
Old 07-04-2019, 11:02 AM   #2
BandJCarm's Avatar
Whatís wrong?
Does not "run"?? It doesn't run if it's cold enough.
Is the interior light on in the refrig when hooked up to towing, with inverter on? If so, it's on,
Go buy a $3.00 item at Lowes that tells inside temp. Then you'll know.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-04-2019, 11:02 AM   #3
Residential Fridge
My residential fridge turned off (no power) after 3 hours without shore power connected. Turned out to be a faulty inverter, replace under two year warranty. 2019 35IK
boomer116ars is offline   Reply With Quote
Old 07-04-2019, 11:47 AM   #4
The low temperature beeper is on after unplugged from land power. After we are plugged in and the temperature goes down to normal the beeping stops. Another person said maybe our inverter is bad. Will check into it
Old 07-04-2019, 11:59 AM   #5
Low temperature beeper or inverter beeper? If your reefer wasn't running and it had a "low temperature" beeper, it certainly wouldn't be running. Never heard of such a beeper. I have heard of low voltage beepers on inverters and especially propane detectors. If that is what is firing your TV is not putting enough voltage into your bank and it is drawing it down.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 08-19-2019, 07:27 PM   #6
We had the same issue with our 2016 Silverback 33IK - worked fine sitting but when traveling would shut off.
Found out it was a bad crimp inside the inverter.
Dealer replaced and haven't had the issue since.
tmsmeltzer is offline   Reply With Quote
fridge
