Old 10-26-2015, 07:23 PM   #1
wls
residential refrig cold weather
I'm from central mi., and hopefully picking up my new CC 38fb2 around the 2-3rd week of Nov. I would like to take it for a trip for a few day before winter sets in hard, maybe to Tn. Is there a shut off for the water to the ice maker, because I really don't want to winterize the ice maker if possible. I have never owned a res refrigerator before. Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 10-26-2015, 07:34 PM   #2
bigdaddy1
bigdaddy1's Avatar
My Cardinal has the ice maker and it has a shut-off that has to be open to have water into the ice maker so if it is off leave it till spring. I can not tell you where yours will be located mine is behind an access panel near the water docking area in the wall of the storage compartment. I got to winterize my unit in the next week or two cause of old man winter....
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline   Reply With Quote
Old 10-26-2015, 08:37 PM   #3
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
Our '13 36CKTS Creek has a ice maker SOV under the kitchen slide just aft of the rear most wheel, a push pull affair. BTW we do have the residential fridge so I don't know if its same with your '16 model. Your best bet is to call Denise Davis at the Cedar Creek factory (260)593-4000. She has helped me plenty of times with various issues, great customer service agent.
Mikey
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 10-26-2015, 08:55 PM   #4
ttanous's Avatar
We have a 38RD. Found mine under the slide about 2 feet from where it turns up behind the ref underneath.
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 10-27-2015, 09:04 AM   #5
wls
Thanks guys, as soon as I get it, I'll look for it. I will definetly ask while the walk around is happening. Thank
Old 10-27-2015, 09:17 AM   #6
Jim34RL's Avatar
I have a 2016 CC34RL with the residential fridge that we did not use the ICE maker at all this summer. I have found the push pull valve and it is behind the rear most driver side trailer tire. The valve is mounted to the frame and than a small 1/8 water line is routed up to the ice maker, there is a low point drain on the water line to the valve. I have winterize my trailer already and I did not winterize this line since we do not use the ice maker. We do not trust the campground water purity, so we either buy Ice or bring ICE from home.
Jim W
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 10-27-2015, 12:22 PM   #7
jkoenig24
Are you SURE that the dealer (or anyone else) has NOT run water through the ice making system? Only way to guarantee safety would be to properly winterize your residential fridge. Unfortunately, Forest River does NOT provide clear instructions on exactly how to do this. I was told by Dynamax folks to check the website. Doing just that, I do NOT see instructions for RESIDENTIAL refrigerators; only RV fridges. If water is left in the ice making system and, an RV experiences a hard freeze, the ice making system WILL be damaged. Forest River, WAKE UP; owners need guidance!
jkoenig24 is offline   Reply With Quote
Old 10-27-2015, 01:10 PM   #8
that is a problem I see across all manufactures, once they get your money they could really care less if you ever get any help on any problem that comes up.
DAPYES is offline   Reply With Quote
Old 10-27-2015, 02:45 PM   #9
Our Cedar Creek has a water filter in the docking station and water to the ice maker is also filtered with another filter in the residential fridge. I have camped all over this country and never had trouble drinking the water the campground provides. Sometimes the water has unresolved minerals that will choke up the filter but the filter still lasts a season. I winterize the fridge only with air and then remove the filter. If water will still flow through it I use it next season. They are expensive IMO. There are instructions posted on this form.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 10-27-2015, 05:16 PM   #10
We have a 2014 38FL CC. I agree with everything that has been said! The on off valve is where it was described. It is a push/pull switch. If you have residential refrig, make sure you get the device (bolt with large washer) or your doors will fly open and hit the granite counter top and dent the door, milk from frig and frozen items will come out and end up on the floor (It happened to us!)
Denise at CC is a huge help and will be a fantastic resource for issues with your Cedar Creek. We had a lot of trouble with our CC 38FL, but Denise, the QA Mgr and Craig, the Plt Mgr went out of their way to help us. We are just north of Grd Rpds in Michigan. If we can be of help, please PM us.
Bill and Michelle Brickey
2014 CC 38FL 45 days in 2014
2008 Ford F-450 Diesel
numbersman is offline   Reply With Quote
