11-04-2018, 01:50 PM
Residential refrigerator
How can I turn off the refrigerator if I can’t unplug it. Is the only way is to disconnect the negative on the batteries
11-04-2018, 01:55 PM
Hey Spock! You should be able to either turn off the fridge/freezer from the controls inside the fridge, turn off the inverter, or both. At least that is the way it worked for my Dad's residential fridge.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-04-2018, 01:58 PM
Our dial where you set the temperature has an off position that turns off the compressor. I used to unscrew the light bulb until I bought a fitting to screw into the socket with a pull chain switch. The only other way I know of would be with the breaker.
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
11-04-2018, 02:01 PM
On my unit you must turn the temperature adjustment up with the + temp for the refrigerator until both the refrigerator and freezer say off. Your may be different just read your owners manual.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
11-04-2018, 03:01 PM
Camper going I into shop tomorrow for two weeks. Painting the cap and fixing road damage
11-04-2018, 07:15 PM
I believe mine has a 15 amp fuse. I flip it off
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
11-04-2018, 07:21 PM
as stated earlier my fridge temp knob is clearly labed off when you turn the temp nob all the way down. also you can turn off the invertor.
11-04-2018, 07:47 PM
Ours has a 15A breaker that we turn off.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
11-04-2018, 08:09 PM
I was thinking that if the power was off the light would be out when you opened the door. I think the light will go out tomorrow when I break connection with the batteries. $5,000.00 bucks fixing the camper.
11-04-2018, 08:31 PM
If it a resi fridge your batteries have nothing to do with it. Just turn off the inverter. it's not on a breaker.
01-25-2019, 05:13 AM
My Cedar Creek 5th wheel has a breaker that is labeled inverter. Turn off the breaker, all power to the residential fridge is off.
01-25-2019, 05:50 AM
"On the road again"
Ditto. Or, if the inverter is off and now power is hooked up the refrigerator should be off.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
01-25-2019, 12:36 PM
Ours has a 15 amp breaker that says inverter/refer Best
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
01-25-2019, 02:41 PM
All power to the fridge comes from the inverter. It either passes thru from shore power or it is generated by the inverter when no 120vac is present.
The breaker controls the 120 vac that goes to the inverter. The output of the breaker does not go directly to the fridge. It goes into the inverter. If the inverter is off the 120vac just passes thru it to the fridge. If the inverter is on the 120vac still passes thru as the inverter is in ‘standby mode’. If the 120vac goes away, ie, no shore power or the breaker is tripped the inverter now switches to its 120vac generated voltage and supplies it to the fridge. The inverter gets its energy from the batteries. If the inverter is ‘off’ and no shore power or breaker tripped then there is no power to the fridge.
