Old 10-23-2014, 06:54 AM   #1
Residential Refrigerator
I am a new owner of a CC 32RL with a residential refer. I cannot find any venting for the refer. It looks to be completely enclosed with cabinetry. I thought all refers needed venting to dissipate the heat. The refer seems to be working fine. What am I missing?
dbunhook is offline   Reply With Quote
Old 10-23-2014, 07:03 AM   #2
If it is setup like ours there is some air space top and bottom that I believe they are using to move air in/out. Some have reported adding (on the 38FL) a vent into the side of the fridge box to help eliminate the heat buildup. I have thought about doing this but have not done so yet.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 10-23-2014, 12:12 PM   #3
Mddle of the Rd Extremist
MeepMeep's Avatar
We have the same set up in our 38FL. We've had the rig out several times and have been full timing since early May without a hitch just the way it was built. So it's been working through the hottest part of the year (and in Florida, at that), it appears to be a good design....so far
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 10-23-2014, 12:36 PM   #4
vinmaker's Avatar
Residential fridges use a different cooling system type. They do not use that heated stack method but replay on compressors and such. As long as there is space above the fridge and behind it, you should be good to go.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 10-26-2014, 05:10 PM   #5
You don't vent your fridge at home to the outside and you don't vent this one. The real issue is combustion gasses and way more heat for the traditional camper fridge.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
refrigerator
