Old 07-25-2013, 06:57 PM   #21
Originally Posted by mlatter View Post
Funny you should say that. I had to help the guy out who was trying to wire it up.
That is funny! It's not exactly rocket science!
That 18 cu ft of cold storage is wonderful! I don't know what I'll think about it when I have to buy 4 new batteries!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-10-2013, 12:15 PM   #22
I have a 38fl with inverter and 4 batterys .don't seam to get a day out of the batterys.made a 5 hr trip and freg was getting warm.how long will the batterys last on a trip.i have 4 6v batterys.
wire1946 is offline   Reply With Quote
Old 08-10-2013, 04:37 PM   #23
Former Full Timer
Duckogram's Avatar
If your fridge was getting warm after a 5 hour trip and you were plugged into your TV you have a problem. My first guess is that your inverter is turned off...
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 08-10-2013, 04:47 PM   #24
jerseyboy's Avatar
I agree your inverter is off I get at least 36 hours out of mine.
jerseyboy is offline   Reply With Quote
Old 08-10-2013, 05:24 PM   #25
Denver, CO
garbonz's Avatar
need more data. are the batts discharged, or just the fridge warm? need a good multimeter to check voltages at battery. if the batts are ok, check again with engine running. then check the invert outlet. report back here.
2017 Fuse 23T
Old 08-11-2013, 06:05 AM   #26
The inverter has a problem .it has a e5 code .it tells me that there is a short some where.and the batt. came with the rv and were connected by the dealer
Old 08-11-2013, 12:07 PM   #27
mlatter's Avatar
I have seen the E05 and OL error on mine, while it was plugged in. I think what was going on was that the auto defrost cycle was happening on the fridge and it sensed it as an overload, even though it should be no more than 500 watts during defrost, and maybe 150 during regular compressor use. It has always worked though. Give the fridge some time to get through the defrost cycle, and if the error is still there, turn off the DC (battery disconnect switch) and AC (unplug your trailer from the AC power source) to perform a restart on the inverter, then try it again.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 08-11-2013, 04:26 PM   #28
What brand and model# residential refer are y'all getting. Seems I read somewhere that the 18CF residential is the same physical size as the Dometic 1350RM which is only 13CF. I know the regular propane refers are not the most efficient. When I bought my '12 CC, it was a dealer ordered unit which had not been delivered yet. I tried to get residential refer installed but my unit had already left the plant. Bummer!! Steve A. Dagro
sdagro is offline   Reply With Quote
Old 08-11-2013, 05:15 PM   #29
Former Full Timer
Duckogram's Avatar
The residential is a whirlpool.
Here are the details:
ID:	37437   Click image for larger version
Old 08-11-2013, 05:23 PM   #30
Former Full Timer
Duckogram's Avatar
Wire1946,
You can use your level-up panel to check your battery status. It has a built in meter.
Your battery wiring diagram is on the bulkhead behind the batteries as well.
If you want to be real thorough you might want to check the terminal lugs your dealer installed to make sure they are crimped tight.
Hope this helps.
