Old 08-11-2013, 05:28 PM   #31
We have a 38FL (2012) with the Residential fridge... Testing we have left the fridge on battery for up to 3 days so far (without much other use of the batteries). We have run dry camping all night and more than half a day without any problems. We did replace the WFCO inverter/charger with a Progressive Dynamics for better battery charging and maintenance.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 08-11-2013, 05:36 PM   #32
Originally Posted by Duckogram View Post
Wire1946,
You can use your level-up panel to check your battery status. It has a built in meter.
Your battery wiring diagram is on the bulkhead behind the batteries as well.
If you want to be real thorough you might want to check the terminal lugs your dealer installed to make sure they are crimped tight.
Hope this helps.
Mine was wired up wrong and I had one lug with a bad crimp. It is the Dealers responsibility to do that work and there is the human error factor!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-11-2013, 05:39 PM   #33
2x on ours being wired wrong..... The trip home from the dealer was 7 hours and the batteries were dead - but only two were wired to the inverter and the other 2 were wired into the charger.... but not the same two... so the two on the fridge at the time were not being charged at all. New wire and all fixed.
Walter & Donna
Old 08-11-2013, 07:34 PM   #34
Originally Posted by sdagro View Post
What brand and model# residential refer are y'all getting. Seems I read somewhere that the 18CF residential is the same physical size as the Dometic 1350RM which is only 13CF. I know the regular propane refers are not the most efficient. When I bought my '12 CC, it was a dealer ordered unit which had not been delivered yet. I tried to get residential refer installed but my unit had already left the plant. Bummer!! Steve A. Dagro
Nope. 18 Cu Ft is 18 Cu Ft. It is huge! Much bigger than any absorption type refer. No more cooler of ice for beer and water. It all fits in one refer! Yehaw!
Old 08-12-2013, 05:45 AM   #35
Thanks a lot guys.it is a whirpool.and I have a 1000 watt xantrex pro inverter.batterys are had to get to only 1 is easy have to discount all of the to check them.
wire1946 is offline   Reply With Quote
Old 08-12-2013, 06:15 AM   #36
KyDan's Avatar
(This is why I use a full sized keyboard! )
Old 08-12-2013, 06:38 AM   #37
Question
Old 08-12-2013, 11:30 AM   #38
mlatter's Avatar
I assume he wears one of these:
Anyway, let us know what you find with your batteries.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 08-12-2013, 12:29 PM   #39
Ok Joe GA. Let me see if I can explain myself better this time. I'll try to be grammatically correct as well. If you had a 13cf absorption and a residential 13cf sitting side by side, the absorption would be bigger because of the design.....I THINK. Can I fit the Whirlpool 18CF in the same hole as the RM1350 without major reconstruction? Also, any idea of cost of Whirlpool 18CF, inverter and 4-6V batteries. Definitely could use the 5CF extra. I am a self employed caterer and cant get out of the cooking mode to minimize my refer capacity. Steve
sdagro is offline   Reply With Quote
Old 08-12-2013, 12:51 PM   #40
It looks to me the limiting dimension for the 18 cu ft will be height. Most are 66" or more in the Whirlpool line and the Dometic is slightly more than 63". Go to the manufacturers web sight and look at the specs for each, some will let you put dimensions in your search.
Timtation is offline   Reply With Quote
