Old 08-12-2013, 02:11 PM   #41
hi all not sure if the inverter is working right.loses voltage very quickly.i have 4 6volt batterys but only 2 are on the ref.how many do you have hocked up to your ref.
is 2 enough to run the ref
wire1946 is offline   Reply With Quote
Old 08-12-2013, 02:34 PM   #42
mlatter's Avatar
All 4 should be hooked up. Two pairs of batteries connected in series, then the pairs connected in parallel for your 12 volt system. There is only one charger in there, so it's only one battery system.
Watch this video:
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 08-12-2013, 02:38 PM   #43
mlatter's Avatar
One other thing. On mine, I have two sets of cables leaving the battery area. One set goes to the inverter, and the other set goes to the rest of the trailer's 12 volt system, including the charger. Those two pairs of cables need to be connected together at the batteries.
Old 08-12-2013, 06:20 PM   #44
Originally Posted by sdagro View Post
Ok Joe GA. Let me see if I can explain myself better this time. I'll try to be grammatically correct as well. If you had a 13cf absorption and a residential 13cf sitting side by side, the absorption would be bigger because of the design.....I THINK. Can I fit the Whirlpool 18CF in the same hole as the RM1350 without major reconstruction? Also, any idea of cost of Whirlpool 18CF, inverter and 4-6V batteries. Definitely could use the 5CF extra. I am a self employed caterer and cant get out of the cooking mode to minimize my refer capacity. Steve
Oops. I guess I didn't do a good job on reading comprehension! Sorry Steve! Can you fit the Whirlpool in the same space as the absorption refer? I'll let you be the judge of that. It doesn't look like a good fit to me. The cost? Sears has it for $706.97. The Dimensions for the 13cf absorption refer are:
63 3/16 high x 32 3/4 wide x 26 1/16 deep
The dimensions for the Whirlpool refer are:
67.375" high x 28" wide x 30.375" deep
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-12-2013, 07:20 PM   #45
VinceU's Avatar
Keep in mind the "effective depth" of a 1350 is between 14=16". The Whirlpool is much greater, without all that plumbing in the back therein lies the reason for much more cubic.
Old 08-12-2013, 09:22 PM   #46
mlatter's Avatar
@wire1946. The diagram below should be roughly how you need to connect things. The two feeds going to the xantrex and the 12 volt panel can be connected at either end of the red and black cables shown. I have shown each connected to a different end, but they don't have to be.
Old 08-25-2013, 06:36 AM   #47
TCW
2014 Georgetown 378XL residential refrig
I just purchased a Georgetown 378xl with a residential refrigerator. It came with two coach batteries. The refrigerator is fully electric.
We will drydock on average twice a year for 30 days each. I bought two Honda 2000 generators to charge batteries.
Do I need anything additional to run my refrigerator during drydock times?
TCW is offline   Reply With Quote
Old 08-25-2013, 07:09 AM   #48
I have a 2013 Georgetown xl378
My coach batteries will power the refridge for 3 to 4 hours only.
If yours are like mine they will ned to be charged up by then.
Too bad Forrest River doesn't install larger banks of batteries.
We love our motorhome but are a little disappointed on the batteries. But we mostly stay hooked up to shore power.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 08-25-2013, 07:47 AM   #49
onetexasoldman's Avatar
I just purchased a 05 Forest River Tsunami and replaced the 8 yes 8 - 6volt batteries OUCH!!
2015 Bighorn 37' Front Living Room
2012 Dodge Cummins 3500 4x4
Live at 9000' in the rockies just out of Colorado springs
onetexasoldman is offline   Reply With Quote
Old 08-25-2013, 11:14 AM   #50
TCW
Thanks for the responses...confirms my assessment.
TCW
