Old 04-09-2015, 04:57 PM   #1
Residential whirlpool frig
I have a 2013 36 ckts with a whirlpool frig I unplug rv and plugged it back in in another outline, frig will not come on , checked breakers all OK, any suggestions Thanks
linjen is offline   Reply With Quote
Old 04-09-2015, 05:12 PM   #2
Res Fridge
Make sure inverter is on.
Locomo14 is offline   Reply With Quote
Old 04-09-2015, 05:16 PM   #3
Are you hooked up to shore power?
Old 04-09-2015, 05:18 PM   #4
Hooked up to shore power!
Old 04-09-2015, 05:24 PM   #5
Former Full Timer
Duckogram's Avatar
For some reason, CC thinks its a good idea to have another breaker for the fridge labeled washer/dryer. I found that out on my '12 when my fridge would not come on... just a thought.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-09-2015, 05:27 PM   #6
Check inverter display to see if it shows a fault. If inverter has a gfi outlet on it check to see if it needs to be reset.
Old 04-09-2015, 11:28 PM   #7
Had electrician look at it ,found microwave frig coffee maker and central vac are fried,power surge or something did them in! hope service contract will cover them!
Old 04-10-2015, 08:00 AM   #8
Jim34RL's Avatar
Sorry for the lost.
Check your entertainment system also and any other electrical attachment that is 110V.
Did you have a surge protector installed either hardwired or portable in line from the Campground power source? This is one of the most important attachments that should be bought first for any of the newer campers.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 04-10-2015, 08:04 AM   #9
I have a 38FL and there is a cb that feeds ref and inverter. never looked to see if anything else is on the same line.
wire1946 is offline   Reply With Quote
Old 04-10-2015, 11:27 AM   #10
kinzoo's Avatar
Originally Posted by Jim34RL View Post
Sorry for the lost.
We also have a 2013 - 36CKTS, same thing happened last spring, like Jim said, check everything, We also lost our fireplace & the radio/DVD player in addition to all the other accessories that you lost.
Don't forget to ck your A/C.
Fortunately, FR original factory warranty covered everything.
It took them forever though....
Have a surge protector now.
Good luck, hope you make out OK...
kinzoo is offline   Reply With Quote
