Old 11-04-2015, 05:36 PM   #1
sabre5er's Avatar
Rim Valve Stem Lock Nut
We recently updated from a 2012 Sabre 31CKTS to a 2016 CC 38FB2. We really like the Cedar Creek.
I was removing my TST air pressure monitors, to replace the batteries. I noticed that the nut on the stem was loose. I checked the other nuts and one other rim also had a loose locking nut.
I wanted to post this to give people a heads up on this issue. I never really thought to checked these before. It could be just on my trailer. But 2 loose nuts?
I guess I really need to update my user name.
Name:   ImageUploadedByForest River Forums1446680148.812671.jpg
Sabre5er
2012 - Sabre 31CKTS-6
2011 Ford F250 Powerstroke
sabre5er is offline   Reply With Quote
Old 11-04-2015, 05:57 PM   #2
CCRVOC
Ramblin Recks's Avatar
I had one loosen up also. Once I tightened it up, it had a very slow leak resulting in replacement of the valve stem.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 11-04-2015, 09:51 PM   #3
keith52's Avatar
Now I need to check mine. Thanks for the heads up.
keith52 is offline   Reply With Quote
Old 11-05-2015, 10:28 AM   #4
sabre5er's Avatar
I really didn't apply much torque to the nut. Used a 14mm socket on 3/8 drive ratchet, and tighten with the head ratchet and just snug them up slightly. Didn't have a in-lb specification, and wasn't sure where to find it.
There is a soft washer under the nut and didn't want to crush it to much. Will keep a eye on them in the future.
Sabre5er
Old 11-05-2015, 12:17 PM   #5
Too old to be too smart
SpringerPop's Avatar
Get a small drop of blue Loctite onto those nuts and a re-occurrence is unlikely.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 11-05-2015, 02:10 PM   #6
camaraderie's Avatar
Mine went on my right front...missing nut entirely. Had blow out and was lucky we weren't going at highway speed when it blew. Ditto the message...it ain't nuts to check your nuts.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 11-06-2015, 01:57 PM   #7
Mddle of the Rd Extremist
MeepMeep's Avatar
Attachment 93718
While doing my "pre-flight" inspection before we left Virginia Beach in August, I found three of them loose. One of them was so bad that we had to have the valve stem replaced.....apparently not an uncommon problem
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
