Old 11-03-2014, 03:16 PM   #1
Rodent block
Has anyone been able to block the big gapping holes that lead up through the front jacks into the storage bin. I have 34RLSA CC.
Arc of the Sun is offline   Reply With Quote
Old 11-03-2014, 03:17 PM   #2
TURBS's Avatar
Steel wool.
Turbs
Old 11-03-2014, 03:29 PM   #3
extremebike's Avatar
I used landscape foam. You can use a plastic bag to hold the foam in place until it hardens. Plastic does not stick to hard when it is dry. it's called Touch n Foam.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 11-03-2014, 04:47 PM   #4
Thank you
Old 11-03-2014, 06:03 PM   #5
Crusader's Avatar
Block Insects and Pests | GREAT STUFF? Pestblock
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 11-03-2014, 07:46 PM   #6
I used expanding foam mixed with steel wool. I also use an ultrasonic repeller and numerous glue traps in the basement area. Don't want any varmints messing with all of the wiring and hydraulics. No signs so far.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 11-03-2014, 08:03 PM   #7
Canadiancrew's Avatar
Been successful in the past to use steel wool and then foam the hole. The rodents can't chew the foam due to the steel wool.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 11-03-2014, 08:17 PM   #8
Thanks. Much appreciated.
