03-05-2018, 02:55 PM
Roller Shades
So far I’ve had to replace 6 brackets and replaced 2 shades and repaired another because of the plastic tabs breaking on the hanger brackets. I’m sure I’m not the only one that’s had problems.
Has anyone come up with an idea to keep the shade from falling when the tabs break?
I’ve worked on several ideas I had but haven’t hit on a fix yet.
03-05-2018, 03:17 PM
All the shades fell last year on the trip to Alaska but the shades fell before we were even in Canada. Cedar Creek installs metal brackets now. See if you can get more brackets from Cedar Creek and anywhere you have two brackets put three in. The back window in the camper fell twice, the last time it messed up the roller. At the rally last year Cedar Creek fixed that and the tech installed four brackets on the rear window. I was given more brackets at the rally. Even the metal brackets won’t hold if there is not enough brackets holding up the window shade
03-05-2018, 03:20 PM
Oh one other thing I found out that a 12in extended drill bit works great. I found one with a number 2 square bit.
03-06-2018, 04:23 PM
I wrapped a zip tie around the bracket to the shade and have not lost a shade since
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
03-06-2018, 05:27 PM
Zip tie idea
Not a bad idea but how did you get two hands in there to work?
I’ve been toying with the idea of a long #10 screw that I would drill small hole thru valance and go just above shade roller (touching bottom part of frame) and set it into wallboard to take the weight off the brackets. About 4 screws on each long shade should be enough.
I’d like to have some input on why it won’t work to help me think it thru.
If it would work it would be an easy do. Of course you’d have to hide screw with paint of something.
03-06-2018, 10:50 PM
I pulled the valence down.
MORryde IS 7000 LB
Kodiak Disc Brakes
03-07-2018, 12:41 AM
After all my shades fell, some twice, I am as good putting up shades as the techs at the factory. I brought a cordless drill just for that.
03-07-2018, 10:26 PM
Are you talking about MCD Day/Night shades? Mine are aftermarket, and not one has fallen, even going to Alaska. Installed by MCD. They are hung by metal brackets/clips, two on the short ones and three on the long. I pulled them all off today as part of remodeling, and they were a pain in the ass to get down.
03-11-2018, 09:14 AM
How do you get the valence down to work on the shades? I have 2 that are broken as well.
2014 Cedar Creek 36CKTS
2013 F350, 4x4,6.7 diesel,CC, DRW 3.73 rear
B&W companion hitch
03-11-2018, 02:29 PM
They are screwed into the wall and in some case the bracket for the shade may have screws that will be used to support the valence. You need to look very carefully to find the screws that are in the valences.
I have had to remove my valences to replace a couple of failed brackets for my roller shades.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
03-12-2018, 09:34 AM
I just got rid of my valances (part of remodeling), and when remounting my shades, I had to use a work around. Originally, they had either two or three metal clips installed in the valance. I mounted a .5"x2" wood strip to the ceiling, then mounted the clips to that. Without the additional support provided by the wooden strip, I'm sure they would rip out as we bounce down the road.
Those that have failed brackets, are they plastic or metal?
03-12-2018, 03:24 PM
Both. Cedar Creek installed the plastic ones at the factory. They were having problems with the plastic brackets and I was given a bag of metal brackets at the factory. The wide shades didn’t have enough brackets so two fell again after I installed the metal brackets. At the rally I was given more brackets as one curtain had fell and messed up the curtain. That was fixed at the rally last year
03-12-2018, 08:28 PM
Wow, hard to believe that they'd go with plastic for the amount of weight that they had to hold. What for, to save a few pennies?
03-13-2018, 08:09 AM
Roller Shades
It is not Cedar Creek but the shade manufacturer who provides the hardware with the roller shade. I called Irvine Shade &Door Inc. who is the manufacturer of the roller shades for replacement brackets. When I called they asked for the style of bracket I had and they said that there was a redesign to the bracket and they would send me replacement brackets. The only roller shades that have failed on my unit were the two for the largest windows in the trailer. The shades only had three brackets supporting them which is not enough, there should be between four and five brackets to support the roller shade.
Jim W.
03-13-2018, 08:23 AM
I believe the only redesign was in the plastic composition. I have a bunch of extras that I keep for if/when they break again. Adding at least one or two more on larger shades definitely help. Spend some time and figure out the valance mounting points and it will save a lot of headache of trying to attach the shades back up, especially on the tall valances.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
07-19-2018, 09:51 PM
We have a brand new cedar creek 33ik and the back window shade the plastic on the bottom fell off.The smaller window in the back the shade has pinholes in it and the light shines through.We have a table that turns into a bed and the top has cracks in it. The stove is crooked. One of the speakers on the outside doesn't work. All minor issues but when you pay the amount of money that they are going for things should be perfect.Hopefully they will address these issues. Will see next week. I had day night cloth shades in the heartland we had. Regretting trading it in. Some things are better tho. More comfortable chairs. Gel coat.Nice stairs. Shower is bigger but bathroom very small. Bathroom door is so weird. Not sure if it was installed wrong. Its a pocket door that doesn't go into any pocket. Didn't notice it as it was locked in open position. Someone else mentioned no surround sound and no bedroom speakers. Next time will pay more attention. lol
