Old 09-26-2016, 02:29 PM   #11
mbbutler's Avatar
You should turn off antenna booster
There is a button next to the cable.
mbbutler is offline   Reply With Quote
Old 09-26-2016, 03:30 PM   #12
I have tried. It does not matter if booster is on or off, the signal from the receiver to tv # 2 will not get thru. I ran a wire from receiver across the floor to tv # 2 and signal was great. When i try to run the signal thru the cable wire it will not get thru with a usable signal. This is why i am going to connect the prewired satellite wire in the roof together and feed from the receiver to tv # 2. It should be a direct line from wall behind receiver to the bedroom where tv # 2 is located. It will have no splitters just one connector joining the two together.
Joe and Teresa
Retired from Georgia State Patrol and very proud of it.
2010 F250 King Ranch Crew Cab 6.4L Turbo Diesel
2011 Cedar Creek Silverback 29RE
gsp050 is offline   Reply With Quote
roo, roof, satellite
