Old 09-24-2016, 05:30 PM   #1
roof top satellite dish
Does anyone know if you can access the satellite wire where the dish is installed from inside the coach. I need to join the satellite wire together in the roof to carry signal from receiver in back of coach to the tv in the bedroom. Do I have to open the area on roof or can I access from inside.
Joe and Teresa
Retired from Georgia State Patrol and very proud of it.
2010 F250 King Ranch Crew Cab 6.4L Turbo Diesel
2011 Cedar Creek Silverback 29RE
gsp050 is offline   Reply With Quote
Old 09-25-2016, 11:06 AM   #2
wanderer69's Avatar
If it was prewired from the factory for the dish then cable is already in place. You cannot access it from the inside. On the roof where the cable from the dish goes in the roof there is a cover. Remove it and you should be able to find two coax. Just install a splitter.
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
wanderer69 is offline   Reply With Quote
Old 09-25-2016, 01:04 PM   #3
Its prewired. I have a dual tv satellite receiver and use a dish on a tripod. When I try to send signal on inside cable wire to rear it is fuzzy and not watchable. Antenna booster interfers and I don't want to change that wiring. Was hoping to use the prewire sat wire to feed receiver to bedroom tv. Did not want to open the roof if I didn't have to. Guess I need to go get some sealant and get to work. Thanks for the reply was hoping I could get to it from inside.
Joe and Teresa
Old 09-25-2016, 02:00 PM   #4
ttanous's Avatar
My 2015 has access inside the cabinet within the bedroom next to the bathroom. In the top of that closet is a cover for the satellite wires and there is 110 volt receptacle and 12 volt receptacle. This cover is directly below the soft spot on the roof that contains the prewired satellite wiring. This closet in the bedroom has the dirty clothes hamper built in the bottom of the cabinet. Good luck hope you have the same thing on your CC.
ttanous is offline   Reply With Quote
Old 09-25-2016, 02:32 PM   #5
Thanks for the info, will check and let you know what I find
Joe and Teresa
Old 09-25-2016, 04:33 PM   #6
Mine has the closet in the very front of rv. The closet is actually in the cap, in the top of closet is what you have and it is labeled for travelr control wires, but only able to get to one wire that has a plug on the end. Can't access the cable wire. Guess I will be climbing on the roof in the morning.
Joe and Teresa
Old 09-25-2016, 08:41 PM   #7
What you described is what I have in my 36CKTS. That is where you would plug into the control box for the Trav'ler antenna. My coax cables were located under the labeled area accessible from the roof only. It was about 18" in from the edge above the entry door... A good distance away from the bedroom hamper closet.
Doug & Cindy
2014 36 CKTS: Titan Disc Brakes, EMS, Trav'lr, 20k GooseBox
2016 Ram 3500 CTD 4x4 CCLB DRW, Laramie, Factory Rear Air Suspension, 3.73
DJNCJ is offline   Reply With Quote
Old 09-26-2016, 08:13 AM   #8
Thanks, thats where i found mine
Joe and Teresa
Old 09-26-2016, 12:51 PM   #9
Telstar's Avatar
You need separate feed for each satellite box, you can't use a splitter. Wired should be accessable in attic area you just have to remove vents, lights, speakers, etc to find them.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 09-26-2016, 01:11 PM   #10
I am not going to use a roof antenna. I have a dish that i use on a tripod that works great, have no problem getting signal to receiver. The main tv at the box has a great picture. I have a dual tuner receiver and cannot get a good signal to the bedroom tv. What i plan on doing is on the roof where my unit is prewired for a dish is to join the satellite cables together as one long piece from main tv to the bedroom and use this cable to carry the satellite signal to the second tv. By doing this i do not have to rewire and bypass the tv booster. I will not need a splitter in the attic. Will only have to use a splitter in the bedroom if i want to have cable or over the air antenna reception in the bedroom. Hope i have made myself clear on what i am planning on doing. As soon as i am able to get some dicor sealant will try this and will post the results as to how it works.
Joe and Teresa
roo, roof, satellite
