Old 09-26-2015, 07:42 AM   #1
kinzoo's Avatar
Sanitize fresh water tank
38 CKTS
How do you add sanitizing fluid to fresh water tank?
All I have on my 38CKTS is a lever to switch from City water to the Fresh water tank.
There is no opening to pour the sanitizing fluid into.
kinzoo is offline   Reply With Quote
Old 09-26-2015, 08:24 AM   #2
PhoneDude 8289's Avatar
Originally Posted by kinzoo View Post
38 CKTS
You would pour it in at the same inlet you use to fill the fresh water tank.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-26-2015, 08:29 AM   #3
bubbles's Avatar
38 CKTS
Pour it in the hose and preselect fresh water tank and fill the tank.
Old 09-26-2015, 09:08 AM   #4
Down the sink drain?
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
CNYCamper is online now   Reply With Quote
Old 09-26-2015, 09:13 AM   #5
Ford Idaho's Avatar
Originally Posted by bubbles View Post
Pour it in the hose and preselect fresh water tank.
Yes.
Bypass the water heater.
1/4 cup of bleach per 15 gallons of water, let it sit over night and then use the water pump to flush the faucets in and outside.
Be sure to run some out of the low point drains.
After the tank runs empty flush with clean water until you can not smell the bleach anymore, again run the fresh water out low point drains.
Old 09-26-2015, 09:17 AM   #6
Re. my post #4, I was thinking gray water tank, not fresh water. Sorry.
Lar & Ruth
Old 09-26-2015, 11:56 AM   #7
2016 Avenger 26BH
you may want to consider using pool grade chlorine instead of bleach. not so critical to rinse as thoroughly then if bleach is/was used. worst case scenario, first bit of water is high in chlorine content no different than a pool. whereas ingesting bleach could mean a trip to emerg. IMO.
Cleon is offline   Reply With Quote
Old 09-26-2015, 12:21 PM   #8
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Bleach won't hurt you if you flush it out thoroughly. That's what I used in Colorado last summer for our well water sanitizing when I was park hosting for the U.S. Forestry Service,,,,,,it was a directive from the Stat of Colorado AND the U. S. Forestry Service.
Grampa Jim is offline   Reply With Quote
Old 09-26-2015, 12:34 PM   #9
Ford Idaho's Avatar
There are commercially manufactured alternatives to bleach available at Walmart and any RV dealer with a parts department.
As posted above if you flush with clean water until the smell goes away there is nothing to worry about.
Old 09-28-2015, 07:24 AM   #10
SilverbackMel's Avatar
Camco has a small, EZ store, plastic bottle of conditioner. Available at CW.
SilverbackMel is offline   Reply With Quote
Old 09-28-2015, 01:40 PM   #11
NCBBA11043's Avatar
There is NO gravity feed
If your rig is similar to my 33IK . . . there is no gravity feed for the fresh water tank. A few have remarked to add the chlorinated water to a hose and force it in under pressure, which works fine. I took a cheap whole house filter, put some garden hose adapters on each end, and fill up the canister with bleach/water. Attach water supply to inlet, attach outlet to your fresh water inlet, and away you go! Easier for me than trying to fill the hose, and if I wanted to, I can hook up a filter system when at a site that has water.
NCBBA11043 is offline   Reply With Quote
fresh water, tank, water, water tank
