07-26-2017, 07:55 PM
Sewer Hose Storage Length
Does anyone know how long the sewer hose compartment is?
07-26-2017, 08:24 PM
Mine is 3 ft
07-26-2017, 08:31 PM
Kasual Kamper
Mine's in the bumper. Can't you just measure the bumper?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
Oh wow that is pretty short. I guess the rest of the hose goes in a container in storage?
07-26-2017, 08:33 PM
The Cedar Creek Champagne does not have bumper. It is a door in the side of the trailer.
07-26-2017, 09:23 PM
Kasual Kamper
Then can't you just stick a tape measure into the compartment to measure it? The hose does collapse.
07-26-2017, 09:40 PM
I don't have the trailer yet. It is on order 6-7 weeks out. I am just trying to decide which sewer hose to get. Someone said it was 3 foot deep so I guess I will put some in the basement storage. Thanks.
07-26-2017, 11:05 PM
Most have bumper and that is 8 feet at least that's average....some add Pvc and mount under rig to help prevent rust...
07-27-2017, 04:10 AM
Mines is in the bumper, so I have a 15' of hose.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
07-27-2017, 04:31 AM
The Rhino-Flex 15 ft hose (most popular), will collapse down to around 3 ft.
2016 Salem 27RKSS
07-27-2017, 07:32 AM
The hose will collapse to fit in compartment on the cedar creek. The problem is thr fittings will not fit.
07-27-2017, 08:41 AM
Cedar Creek does not have a bumper. I brought a container from Walmart to keep my hose in
07-27-2017, 09:06 PM
I have the sewer hose that couples together. I put one in the sewer hose compartment. One link fits perfect. Mine is on the side of the coach about 4 feet off the ground. I keep my regular use hose in a container with the 90 degree. The only time I pull the hose from the sewer hose compartment is when I need additional length. One link shrinks down fine to fit into the compartment.
07-31-2017, 03:06 PM
sewer hose storage
Top
The original tube was 3' long and Rhino-Flex would not fit in.
Bottom
Fence post cover is 6' long.
Rhino-Flex lays in rain gutter.
This is a 2013 Cedar Creek 36CKTS
C.B.
07-31-2017, 08:16 PM
I have a Rhino-flex 15' and a 10' extension, normally only use the 15'. We keep them in a "Steriilite" container in the front hold. We add a splash of Pine-Sol and a 1/2 gal of water. When we arrive at the next site the hoses are nice and clean.
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
08-01-2017, 07:13 PM
That built in sewer hose holder is useless. Haven't found anything I have that will fit inside it it. Works about as good as the junk built-in vac.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
08-02-2017, 10:26 PM
That option of creating a fitting for a tube under the rv is the best option in my humble opinion. Keeps it out of the way. No odors inside from Mr Stinky.
08-03-2017, 08:32 AM
I have to agree on the sewer hose holder, but the wife likes the built in vac. She also uses a rechargeable vac.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
08-03-2017, 09:37 AM
I have two Rubber Maid containers that hold my sewer hose and black water flush hose. The containers also hold the clear plastic straight adapter and 45Deg elbow, along with the sewer hose support. I have the Rhino Flex Sewer hose, 10 foot long hose assemblies with end caps, three of them. I have found the connectors do not fit in the onboard storage compartment so, that is why I have the plastic storage bins. I have a spare sewer hose with no connections on the ends in the onboard storage compartment.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
08-03-2017, 07:16 PM
I have one plastic container that I got from Walmart to store my sewer hose support plus the the Rhino Flex Sewer hose. I use my outside shower hose hooked up to the black water tank flush, we never use the outside shower. I have a back flow preventer on that hose. I have 25 feet of sewer hose plus ten more feet that I just brought at Walmart for the rally
