05-19-2015, 06:06 PM
Sewer smell in front compartment
2014 silverback 35qb4
05-19-2015, 06:08 PM
Had this issue every since I've owned it and no help at all from the dealer....
Need some more information.
Did you put chemicals in the black water tank?
If so, how long since you dumped the tank?
Mark B.
2021 GMC 1500
Anderson WDH
05-19-2015, 06:27 PM
I've put chemicals in it and it still has the smell. From the time I dump until I dump again....
05-19-2015, 06:30 PM
Also checked for leaks and as far as I can tell there are none
05-19-2015, 06:57 PM
Do you have a washer/dryer hook up? If so make sure you have some water in drain trap or if not used sealed. Our CC 36 CKTS has a washes/dryer and found that the trap was dry. Also insure that seal on toilet is sealing good with water standing at least 1 inch in bottom when closed.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
05-19-2015, 07:18 PM
Thanks I have washer dryer hook up but no washer dryer have to look for that
05-19-2015, 07:30 PM
I also have a CC36CKTS with a black tank smell problem ,it first it was in the storage compartment, that was fixed by the dealer, I don't know how that was done, now that smell is coming from the top drawer in the bedroom ,I noticed that after taking a shower with the vent fan running,the wsher drain has a plug on it, and no smell in the front storage, I have been told all the tank vents are tyed together , any ideas thanks im using chemicals, another factor the toilet bubbes before it flushes when the tank is half full or more ???
05-19-2015, 07:39 PM
Those caps are what is called a vent less air cap they are suppose to let air flow like a check vale but don't always work right. You might make sure you have some water in the trap also that your top cap is not clogged or stop up. After taking the vent less cap off and cleaning the little check vale seal my problem stopped
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
05-19-2015, 07:55 PM
Cardinal Gerry
One thing more to look for, are your batteries properly vented?
We had a similar problem, and it was the battery vent giving us a rotten egg smell.
OK thanks everyone I've had this rv for about a year now with no help from the dealer... I'm just trying to figure this thing out... Other than that I love the unit.
05-19-2015, 08:12 PM
Don't know if it would help your problem, but might try a cyclone sewer vent. It's suppose to pull and odors up out of your black tank. Attaches to the top of the sewer vent, takes about 15 minutes to install. Good luck
Henry & Tena
05-19-2015, 08:16 PM
You might have some Magic Plumbing like I had !! Pipe in wall was not glued together...after 5000 miles of bumps it came apart.
05-19-2015, 08:22 PM
like this
05-19-2015, 09:31 PM
and where was this "majic plumbing "at?
05-19-2015, 09:35 PM
look for the vent on the roof, then open the wall below inside unit. Surprise!! Plumbing that is not glued together.
05-20-2015, 04:45 AM
Lol I love surprises..... Thanks again everyone
05-24-2015, 06:22 AM
CCRVOC
A friend had the same problem. discovered that the vent pipe was installed too low in the black tank and the when the level in the tank got above the pipe, there was no place for the air (and odors) to vent to. Another symptom he noticed was that when flushing the toilet, it would "burb" air when flushing.
Jerry and Irene
2015 Chevy High Country 3500 CC/LB D/A -- 2013 Cedar Creek 34R
nights camped - 2011 = 76; 2012 = 153; 2013 = 88; 2014 = 57; 2015 = 95; 2016 = 49; 2017 = 71
miles on CC - 2011 = 6035; 2012 = 14779; 2013 = 9066; 2014 = 5263; 2015 = 11179; 2016 = 5869; 2017 = 7290
05-24-2015, 07:18 AM
Great thanks rockfarmer sounds exactly what mine is doing
