Old 03-08-2015, 05:04 PM   #21
trbomax's Avatar
Originally Posted by Ford Idaho View Post
I'd bet the tax assessor see's it once or twice a year.
Around here that is seen as an" improvement" and taxed forthwith.
I can get around that.I already have 2 ag buildings for the horses and mules,if I stack a row of round bales the length of it,2 high on the north side,it will be a perfect windbreak and qualify as an ag building.Ag buildings do not require permits and are not taxible as such,but still fall under the 12' high rule.
trbomax is offline   Reply With Quote
Old 03-08-2015, 05:10 PM   #22
Crockett's Avatar
A brief clarification on my part. Awnings usually fail from rain collection above or wind from underneath. If a person has a 24' wide canopy to accomodate a awning out and no side sheeting unlike the previous pics, it would seem that it could still be susceptible to winds. That was the logic to my post...that and it would seem maybe there not be much of an advantage to having it out.
Crockett is offline   Reply With Quote
Old 03-08-2015, 05:19 PM   #23
Mojojojo's Avatar
So make the building 12ft and then pit one side down with drainage or a pump incase it gets water in it ... Just a thought
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 03-08-2015, 05:24 PM   #24
Ashley's Avatar
Originally Posted by OldCoot View Post
Thank you very much. I really appreciate the trouble you went to to get the pictures.
You're Welcome Sir.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 03-08-2015, 07:13 PM   #25
We have a 32RK. Built a metal cover 40'l, 18'W and 13.6 to start H, which went up to a peak of 16'. Pushed water and electric to it. Concrete slab is optional but we did it to keep off the ground when we are home. Covered with metal roof panels down partial on sides. No trusses, plenty of open. Guaranty to 90 MPH winds. Great.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 03-08-2015, 08:02 PM   #26
PPST OGCDG
Frank-VA's Avatar
I have a Camper Shed that is 18' wide 15' tall and 38' Long.
Pole Buildings | Steel Pole Buildings | Newmart Builders Inc.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 03-09-2015, 08:12 PM   #27
45 long by 18 wide and 12 ft legs covered on all sides with an open front
Pitcrew18 is offline   Reply With Quote
Old 03-09-2015, 08:33 PM   #28
gashog's Avatar
I went 40' long 24' wide 12' walls. With my TT I needed less that 12' to clear the AC units on the height so I had gable ends installed. Solved the problem keeping the weather off the Windjammer, but now I have a bird problem.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-09-2015, 08:58 PM   #29
Old car's Avatar
We are kicking the idea around and luckily I have the room since we are out in the country. We are thinking 14 foot walls X 24 feet wide X 45 foot in length. Our fiver is 38 feet long but I want room to be able to get all the way around it in case I have to do any work. Build it big enough the first time.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 05-06-2015, 12:59 PM   #30
StepanFetchit
Rdeemat's Avatar
I'm just wondering why one would use their awning under a shelter. My 37RTDS Cedar Creek is under a 40ftLx18ft.Wx15ft.H and no longer need to use my awning.
Rdeemat is offline   Reply With Quote
fifth wheel, wheel
